quadra drive - JeepForum.com
post #1 of 9 Old 08-15-2009, 02:40 PM Thread Starter
bayer
quadra drive
i have a 2004 grand Cherokee limited. i went wheeling with some friends today, and we noticed that when im in 4all time. that my front wheels dont work but in 4 Lo everything works fine. is this normal?
bayer is offline
post #2 of 9 Old 08-15-2009, 05:03 PM
gatorayde
They won't be 100% locked but the front wheels should be turning a little bit. If they do not spin at all when in 4wd full time, then something in your T case is bad.
gatorayde is offline
post #3 of 9 Old 08-15-2009, 09:59 PM
MarkoPo
MarkoPo's Avatar
2005 WK
You should be using the four wheel part-time, that locks the front and rear axles together.
05 Grand Cherokee Limited 5.7 Hemi
06 pontiac Torrent AWD
96 Grand Cherokee Laredo 4.0 newest edition to the family.
Hemi Club member #2
Bonafide Gun Guru
MarkoPo is offline
post #4 of 9 Old 08-15-2009, 10:13 PM
gatorayde
247 transfer cases only had two options: 4WD full time and 4LO
post #5 of 9 Old 08-16-2009, 02:16 AM
SnowLeopard
It sounds like the clutchpack or however it is the 247 works to limit slip is worn out. When that happens, it remains in 2wd all the time. 4w-low in the 247 reverts to the old true lock like the 242 and second gen 249's had. It bypasses the limited slip stuff. I don't know all the ins and outs of it, just the basics.
SnowLeopard is offline
post #6 of 9 Old 08-16-2009, 06:36 AM
ruggedscotsman
2007 WK
The 247 transfer case (Quadradrive) uses a gerotor pump that senses speed difference, not torque, between the front and rear axles. In 4alltime the rear wheels get all the power until they spin faster than the front, and then power is progressively transfered to the front. 4Lo locks both axles together at a 2.72 reduction gear. Unless you were spinning your back wheels, the front won't have any power.
ruggedscotsman is offline
post #7 of 9 Old 08-16-2009, 07:18 AM
comptiger5000
Snow - That's a pretty likely answer. I second that.
comptiger5000 is offline
post #8 of 9 Old 08-16-2009, 07:27 AM
sandman
what your explaining is normal.
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 9 Old 08-16-2009, 07:36 AM
skain8
skain8's Avatar
x2. If you left it in 4 all time, your front wheels wouldn't "work" unless they had to.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 05:45 PM
quadra drive II or quadra trac II 2008 WK ? bill.rivard WK Grand Cherokee & XK Commander Forum 12 06-16-2009 08:14 AM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 05:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 02:21 PM
Quadra-TRAC vs. Quadra-DRIVE ptmeyer84 ZJ Grand Cherokee Forum 7 04-23-2007 06:56 PM
