Purple /black and white/ black wires behind head unit - JeepForum.com
post #1 of 20 Old 02-15-2013, 06:39 AM Thread Starter
richh789
1987 YJ Wrangler
Installing a head unit into a 98 Grand Cherokee Limited, everything turns on but no sound comes out. There's a white and black wire and a purple and black wire with a plug that I don't have hooked to anything. I wasn't sure if these turn on the factory amp under the rear seat. Or if I just need to run speaker wires to each of the speakers.
richh789 is offline
post #2 of 20 Old 02-15-2013, 07:19 AM
melk
Well are you trying to utilize the factory amp, or bypass it?
melk is offline
post #3 of 20 Old 02-15-2013, 07:26 AM Thread Starter
richh789
1987 YJ Wrangler
I believe previous owner used amp. Stock harness is there, the radio has jeep harness on it. I would like to use amp if possible
richh789 is offline
post #4 of 20 Old 02-15-2013, 07:26 AM
um7267
Did you use a wiring kit or butcher the stock wiring?
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #5 of 20 Old 02-15-2013, 07:34 AM Thread Starter
richh789
1987 YJ Wrangler
Pioneer Radio came out of a xj and has harness on it. They appear to be the same plugs, and plugs right in
richh789 is offline
post #6 of 20 Old 02-15-2013, 10:04 AM
4Slow9erHybrid
I believe those colors are used for the CCD bus. In the limited models the head unit communicates through the CCD bus to synchronize the clock with VIC. So I doubt you need these wires for you aftermarket head unit.
1997 JGC Laredo 4.0 4x4 99900mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline
post #7 of 20 Old 02-15-2013, 12:13 PM Thread Starter
richh789
1987 YJ Wrangler
Any suggestions on how to troubleshoot this thing? Or am I better off just running all the wires and ditching Factory amp
richh789 is offline
post #8 of 20 Old 02-15-2013, 10:49 PM
Scopez
1994 ZJ
Bypass factory amp and you're good. Search on how to bypass it, I believe you just plug the connectors together somehow? Not 100% sure, never had to do it.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #9 of 20 Old 02-16-2013, 10:01 PM
Wheeler97
The wires may be different for an xj. I tossed the paperwork from my radio upgrade. I didn't have to do anything special on mine to get the factory amp to work. Might try getting a new plug adapter from Wally World. They're under $20.
Wheeler97 is offline
post #10 of 20 Old 02-17-2013, 05:36 AM Thread Starter
richh789
1987 YJ Wrangler
The radio from xj didn't have power antenna wire hooked up. That must work as an amp remote. Got it working now
richh789 is offline
post #11 of 20 Old 06-07-2013, 10:08 PM
Mad-Duke
97 Jeep Grand Cherokee limited
So I ran into a similar issue... I made life lesson mistake and butchered the stock connector, not realizing until after there are adapters to connect to the aftermarket radio.
The wire diagrams I used explained all the wires except for the Purple/Black and White/Black wires....
The issue I am having is I am receiving no sound out of any of my speakers. I get power to the new radio but no sound. Any suggestions or ideas that I could try to get this working?
Mad-Duke is offline
post #12 of 20 Old 06-08-2013, 02:03 PM
Mad-Duke
So Does anyone know what the Purple/Black and White/Black wires do exactly?
Mad-Duke is offline
post #13 of 20 Old 06-09-2013, 08:26 AM
kensnelling
If I'm not mistaken those are the wires for the steering wheel radio controls. I have the OE radios in mine, but I've read on here that if you install an afternarket radio in a jeep with steering wheel controls and don't use an adapter you'll have no audio.
Ken
kensnelling is offline
post #14 of 20 Old 06-09-2013, 08:46 AM
Scopez
1994 ZJ
Don't forget to bypass the factory amp if you have the infinity gold package!
Scopez is offline
post #15 of 20 Old 06-09-2013, 05:56 PM
Mad-Duke
Ken
Ya I currently have no audio.. I have an adapter inbound so hopefully this fixes my no audio issues when it arrives and I set it up.
As a matter of fact I do. Do I have to bypass it? and how do I go about doing that?
Mad-Duke is offline
