#16 | ||
yea, i like the option to turn 4wd on and off. I've heard that towing with it puts a lot of strain on the transfer case which isn't really necessary.
#17 |
I mean "lifting" as a little redesign that was done at 96. You know- new interior, new axle, new t-case etc.
The t-case doesn't allow you to select 2WD mode, it's automatic, but still transmits 100% torque to the rear until the slip occurs.
POLISH JEEP OWNERS CLUB #11 Anyway, nothing will beat Suzuki :D |
#18 | |
another question. how hard is it to replace the transfer case in one of these? |
#19 |
It's easy, but this 249 on-demand t-case is very strong, so it would be the best choice for towing for my taste. The only problem is worn viscous coupler that you may read about here and there...
#20 | |
easy sounds good heh. i have to many bad memories from my dad as a kid working on ford trucks, aka, royal pains in the @$$ |
#21 | |
Location: Powder Springs, Georgia/University of Tennessee
Ben 1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts GA Trail Riders |
#22 |
Find a cheap 1/2 ton truck with a V8. Should be able to get a beat to crap work truck with good running gear for a good price, and you'll actually get a frame.
And does your trailer have brakes? If not, DO NOT use a ZJ. A ZJ's brakes can barely stop one rig, let alone two.
95 ZJ with stuff |
#23 | ||
#24 |
Weight distribution hitch, if I remember correctly, can't be used on a unibody frame.
#25 |
The numbers 46 and 44 mean the torque rating. R means rear wheel drive. E means electronic and H means hydraulic, both refering to how the tranny is controlled. Chrysler makes a pretty good hydraulic transmission (727 torqueflight for example) and not the best electronic transmission. Even the newer ones aren't the best but much better.
#26 | |
I'm pretty sure that is inaccurate. ...Without being able to remember direct quotes or links, I am nearly certain it is common to use WD and sway control hitches on unibody suvs. You will see this very regularly when towing the travel trailers. |
#27 |
I guess i'll have to call the manufacterers and see what they say. thanks for the heads up.
#28 |
WD hitches can be used on both, not sure where you heard that from
the ford pickups are pretty easy to work on, chevy pickups are even easier (older ones) why not look for a 2wd one of those? if its only going to haul 7 times a year i just think these trucks are not any fun to haul in at all, and a GC vs a 1/2 ton pickup hauling the 1/2ton wins hands down all that being said each to his own, your hitch setup may be a bit pricey though
2005 Jeep Grand Cherokee 5.7L Limited - Stock 1998 Jeep Grand Cherokee 5.2 Limited - Alpine 9852, Pioneer "6.5s(x4), Removed Sway Bars, Hayden 18,000GVW Trans Cooler, Modified Intake Silencer, muffler delete, IAT Relocated, 1" Intake Spacer, Pioneer 760watt mono block, Two 12" Pioneer Subs, 180 T stat 1990 Nissan 300zx NA 5spd - Stillen Catback, Panasonic HU, Pioneer 6.5s(x4) 2003 Aprilia SL1000 Falco - Slip-On's, Arrow Chip, Airbox Mod |
#29 | |
#30 |
Do not forget about stopping this rig, you need brake hook-up ,also the combined weight on your "towed set up " weights more than the "tow rig" .NOT a good thing. This cannot end well!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
