Quantcast Purchasing Jeep for Towing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Purchasing Jeep for Towing
Old 07-07-2007, 12:18 AM   #1
lightningd
I was told the Grand Cherokee would be a good cheap vehicle to tow my race car with. So right now, i'm in the market for one (93 to 97), but i would like to know what to look out for when looking over one, what goes bad, and if anyone has any recommendations as far as auto/manual and 6/8 cylinder. The total trailer weight would be about 4000 lbs, and i plan on using the weight distribution hitch. any help would be wonderful
lightningd is offline   Reply With Quote
Old 07-07-2007, 12:31 AM   #2
FatAlbert
unless you go with a 93 or early 94 (and get lucky), you are only given the option of an automatic tranny. As far as I6 vs V8 and towing is added in the mix? V8 all the way. I have a I6 and it just barely has enough power to satisfy me, I couldn't imagine pulling 4000 lbs with it.. My dad has a V8 and it is truly a night/day difference. Also, think about investing in a tranny cooler in whatever you get.
99WJ :: I6 :: Stock
FatAlbert is offline   Reply With Quote
Old 07-07-2007, 12:59 AM   #3
slick2570
welcome.
Welcome to the forum! I'd totally go with the V8. I also own an I6 and don't see it living a decent life if you pulled 4000lbs on a somewhat regular basis. On a side note, got any pics of your race car??
-Eric
2003 TJ Rubicon - stock for now
1999 WJ - Gone
slick2570 is offline   Reply With Quote
Old 07-07-2007, 04:19 AM   #4
lightningd
ok, judging from that, looks like V8 all the way. As far as tranny coolers, i've heard they are definitely worth it when it comes to towing.
How well do the automatic trannys hold up, and does the V8 come with the manual in those early years?
pics of the racecar are in the link below about halfway down the page. it's a bit rough around the egdes right now, but thankfully it's a lot faster than it actually looks. and if 700 hp V8 monsters are you thing, it probably isn't your cup a tea, heh
http://www.accordinglydone.com/forum/showthread.php?t=14442
Old 07-07-2007, 07:40 AM   #5
JG_Canuck
Def. get the V8.
Heat is the #1 killer of transmissions. If you can find a ZJ with the tow prep package it will have an aux cooler. If not, it's quite easy to add one.
JG_Canuck is offline   Reply With Quote
Old 07-07-2007, 08:15 AM   #6
madcabbie
98 5.9!
I would but hey thats me. YOu dont need a stick shift. So i wouldnt base your search off it(its gunna make it harder)
As much as I hate to say this....you dont need a jeep either. I can think of a ton of better tow vehicals that would be low priced...
[B]99 WJ[/B]
4.0l|Westin Side Steps|Safari Bar|Pro Comp Explorer Lights| Rustys Catback|31in Yokahama Geolander AT II's|KOR 2.5in BB|V8 UC springs for a total of 3.5in Lift|Rubicon Shocks|OME SS|
Everytime Someone calls a Jeep, an SUV, [SIZE="4"]GOD[/SIZE] Kills a kitten.
madcabbie is offline   Reply With Quote
Old 07-07-2007, 11:25 AM   #7
dooboy2112
If it was me and I was going to get a vehicle for towing I would get a truck and stay away from a unbody anything that’s my
2000 Grand Cherokee Limited
2000 Wranger Sport SOLD
1979 Wagoneer SOLD
http://www.oclakerfans.com/
dooboy2112 is offline   Reply With Quote
Old 07-07-2007, 12:10 PM   #8
Joeyicu
the GC's stock suspension is softly sprung, towing, witch i have done alot of with the girls truck is a varry uneasy feeling because of the way they are sprung
with the V8 and 4k you wont notice the load back there power wise, just with the suspnesion, a car trailor and my 3900lb tbird back on the trailor, probably weighs in around 4500 or 5000, when i towed with that power was plentiful, it was just the swaying and taking higher speed corners, it makes your stomach turn.
but all this considered i am also usually use to hauling with my F250 diesel's so i dont know how it compares up vs other 1500 and smaller type trucks
and yeah i would also consider alot of different options before geting heart set on a GC
what kind of requirements do you need for this tow vehicles
2005 Jeep Grand Cherokee 5.7L Limited - Stock
1998 Jeep Grand Cherokee 5.2 Limited - Alpine 9852, Pioneer "6.5s(x4), Removed Sway Bars, Hayden 18,000GVW Trans Cooler, Modified Intake Silencer, muffler delete, IAT Relocated, 1" Intake Spacer, Pioneer 760watt mono block, Two 12" Pioneer Subs, 180 T stat
1990 Nissan 300zx NA 5spd - Stillen Catback, Panasonic HU, Pioneer 6.5s(x4)
2003 Aprilia SL1000 Falco - Slip-On's, Arrow Chip, Airbox Mod
Joeyicu is offline   Reply With Quote
Old 07-07-2007, 03:20 PM   #9
lightningd
Originally Posted by madcabbie
98 5.9!
I can't afford something that high.
What other vehicles do you suggest?
I don't really need an SUV, but decent trucks are kind of expensive. Here is what i'm looking at. I don't need the jeep to daily drive, i already have a gas friendly commuter. I could rent a tow vehicle for the 7 times i need it during the year, which would be about $2100. But, I have to select it without them knowing i'm towing. However, I wouldn't have to worry about maintenance of the vehicle. So, $2100 was kind of the range I was looking around. I just bought the car and a trailer, and if i get something i have to make payments on, which includes full insurance, then i won't have enough money to legitly race. If the truck lasts 3 years and dies, then so be it, i still saved money.
From what i've been reading, if you get a weight distrubution hitch along w/ the sway kit, it really helps in this department. People i've talked to that use it say it's a night and day difference.
What, if any, mods are there to do to the suspension to make it a better tow vehicle?
thanks a ton for the help guys
Old 07-07-2007, 03:26 PM   #10
SteelBlue_WJ
Say What??
SteelBlue_WJ's Avatar
i may be off from drinking but doesnt the WJ have a sub frame in the back portion of the vehicle to raise towing capacity?
Edit:
Yes it does...
http://www.usedtrailers.com/mrtruck.htm
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline   Reply With Quote
Old 07-07-2007, 03:39 PM   #11
Sporer65
Location: Powder Springs, Georgia/University of Tennessee
If you get a ZJ. Try your best to get one with a tow package. Class IV hitch and tranny cooler stock. No doubt the V8. You might like to add some air bags in the rear springs to help out some.
Ben
1993 Jeep Grand Wagoneer ZJ V8: Rear Aussie, 3.5" Lift, 31" M/Ts
GA Trail Riders
Sporer65 is offline   Reply With Quote
Old 07-07-2007, 04:01 PM   #12
will_b
buying another vehicle actually cost more, when you put tag, tax, maintenance, insurance and repair cost into consideration. Is it possible you can make the race car street legal? or maybe just sell your dd and have a all-purpose suv/truck.
will_b is offline   Reply With Quote
Old 07-07-2007, 09:06 PM   #13
nitecop
under $2100? a decent tow vehicle? I am not sure these two go togetherusually if i would tow 4000 lbs with somthing often
it is not gonna look decent if it good mechanicly. If it looks nice its going to have mechinal problems.
Example I bought a truck for farm use. a 77 f150 12mpg looks primer grey hood roof and one fender. whats the black truck worth?? $1k-$1500 just a good old 4wd work truck.
I bought a 79 f150 for a project/future parts towed it with 77.
79 on the heavey trailer weighed 7500 lbs the older truck towed it fine.
But this old truck look like a heeping pile.
Jim
United Steelworkers Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline   Reply With Quote
Old 07-08-2007, 05:02 AM   #14
lightningd
thanks...
well i punched all the numbers, and not including maintenance, having both vehicles while daily driving the commuter, costs the same as just having the jeep only as a commuter.....thanks to gas mileage.
no way in hell i'm driving that thing on the street, especially in VA. sometimes i think you could get pulled for having a non-stock paint job.
yea, i don't really care about the looks, as long as its mechanically sound. I can do maintenance myself and have good resources when it comes to that (think, 20ft tall garage with lift )
bringing me to....if i bought a V8, what things would i want to check that are a regular problems (ie, honda accord valve cover O-rings aka oil soaked spark plug wires, etc.)
thanks again
Old 07-08-2007, 05:11 AM   #15
mendelmax
And, if you'll be looking at ZJ anyway, then take post lifting one- after 96. It will give you stronger rear axle and a bit better tranny, not mentioning better t-case (with on demand engaged front instead of all time 4wd).
POLISH JEEP OWNERS CLUB #11
Anyway, nothing will beat Suzuki :D
mendelmax is offline   Reply With Quote
Glock Forum
