Pulsation in overdrive - Page 2 - JeepForum.com
post #16 of 20 Old 05-15-2013, 03:07 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Originally Posted by speedbucket View Post
i've had this same thing for 75k miles with no change in ti
wwwwwwwwwwwwwwwwwwooooooooooooooooooooooooooowwwww wwwwwwwwwwwwwwwwoooooooooooooooooowwwwwwwwwwwwwwww ooooooooooooooowwwwwwwwwwwwwwwwwwooooooooooooooooo ooowwwwwwwwwwwwwwwwooooooooooooooooowwwwwwwwwwwwww wwwww
sounds like that^ no rpm change no felling in the seat, i just figured it was harmonics of the drivetrain. it makes me sleepy
your's probably is the mount. there was a TSB on the transmission mount causing a harmonic vibration at 1500rpm at highway cruising speed.
ratmonkey is offline
post #17 of 20 Old 05-15-2013, 03:16 PM
tucsonzj
Tsb? And would you assume same for mine?
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #18 of 20 Old 05-15-2013, 03:46 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the TSB (technical service bulletin) applies to the old longitudinal trans mount the early zj's had 93-95. i believe the fix was to update to the late style mount and crossmember.
post #19 of 20 Old 05-15-2013, 07:52 PM
speedbucket
I was going to make a new support with two longitudinal bushings spread about 6" out when I do my flat belly x member. See any issues with this?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #20 of 20 Old 05-16-2013, 06:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
might get more harmonic vibes that way.
