Pulling a U-HAUL Car Dolly??? - JeepForum.com
post #1 of 19 Old 11-12-2007, 08:41 AM Thread Starter
tjsgrecc
Is U-haul going to let me use a car dolly behind my Jeep with the factory hitch to pull a 89 jeep wrangler behind it? I know they can be sticklers about letting people do stuff behind SUVs. I looked it up online and it says something about detaching the drive shaft and stuff. I am a little concerned. Has anyone ever rented one of these with there cherokee? Should i lie and tell them i am going to be using a new dodge 4500 ?
Any help would be appreciated cause I don't want to make a 500 mile trip for nothing.
99 WJ Laredo V8 Quadra-Drive
02 WJ Laredo V8
99 WJ Limited V8-Sold
00 WJ Laredo I6 2" Lift-Sold
tjsgrecc is offline
post #2 of 19 Old 11-12-2007, 08:53 AM
nashmd454
nashmd454's Avatar
not really sure what you are asking...I rented a uhaul and a car trailer to tow my jeep. If you are looking at just the dolly (the one that lifts just the front up) then they might have a problem...seeing as how it is all 4 and not just the rears that turn. If it was me...I would rather have my jeep on a trailer and not justthe little dolly...more stable and less wear on the rig.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #3 of 19 Old 11-12-2007, 09:03 AM Thread Starter
tjsgrecc
I here you on that... this thing doesn't run and i don't believe the front is even hooked up. it doesn't have actually jeep parts in it. It has a big transmission and an atlas II t-case. both haven't been turned over ever, i don't know if they are hooked up. i would like to get a full sized one if they are available but who knows thats why i was asking for recommendations. basically my friend and I are buying it and i am towing it home. whats the cheapest route for me to take?
edit: i dont think this thing even comes with seats in it and its all rusted out im sure but it does have a 258 I6 in it.
02 WJ Laredo V8
tjsgrecc is offline
post #4 of 19 Old 11-12-2007, 09:13 AM
micifus
Original GC'er
micifus's Avatar
How far are you towing it? you need to compare how much it weight to how much your rated for. Just go with the stock weight of the wrangler.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #5 of 19 Old 11-12-2007, 09:25 AM Thread Starter
tjsgrecc
a little over 400 miles on the interstate, it prolly dosnt weigh over 3500
02 WJ Laredo V8
tjsgrecc is offline
post #6 of 19 Old 11-12-2007, 09:31 AM
BLACKzj52
if the front end of the wrangler isnt hooked up or the t-case is shifted into 2wd or nuetral u should be good
BLACKzj52 is offline
post #7 of 19 Old 11-12-2007, 09:38 AM
alivenkickin28
why buy it if its rusted out and doesnt even run???
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #8 of 19 Old 11-12-2007, 09:39 AM Thread Starter
tjsgrecc
ya i thought so also, i want to look into getting a full trailer but i am not sure on the availability of those or the price... im sure you guys are jealous that i will have a bomb a$$ wrangler soon.
02 WJ Laredo V8
tjsgrecc is offline
post #9 of 19 Old 11-12-2007, 09:46 AM Thread Starter
tjsgrecc
its not really rusted out just a little around the hinges on the doors. it has new floor panels i just found out. we are going to be building a mud truck out of it so it doesn't matter what it looks like as we will be chopping the body off. it isn't going to be street legal I'm sure, maybe but, its all set up and ready to go for what we want to do. the engine runs its just not hooked up to the transmission atm.
anyway back to the original discussion about getting it home... if you want to read about the jeep check the YJ section in about a week.
02 WJ Laredo V8
tjsgrecc is offline
post #10 of 19 Old 11-12-2007, 11:28 AM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
Ran the #s through the uhaul site and it shows it as a recommended towing setup so shouldn't be a problem.
http://reservations.uhaul.com/Reserv...b/Default.aspx
I used my 93 to pull a Grand Am home 2 weeks ago and they never batted an eye at my setup. Just make sure your trailer wiring works and stay to the recommended max 45 MPH stated by the sticker on the tow dolly. Only problem I had was the unladen dolly flying a foot in the air over the bumps behind me, seemed it towed best about 75 MPH. That and the dolly sticks out a foot on either side of the GC, not fun on narrow streets in the city during rush hour.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
post #11 of 19 Old 11-12-2007, 11:38 AM Thread Starter
tjsgrecc
well im only going to have to drive on 1-75 at about 75mph through flint and Detroit with possibly some snow/icy roads and over the Mackinac Bridge so it shouldn't be to bad
02 WJ Laredo V8
tjsgrecc is offline
post #12 of 19 Old 11-12-2007, 12:26 PM
ZJPunk98
I didn't read anyone's posts yet but I worked for Uhaul for two years and here is the deal:
You will be able to use the tow dolly if you are pulling with a grand cherokee or cherokee.
When they talk about detaching the drive shaft, Uhaul is referring to the vehicle being towed. A tow dolly only lifts the front end of the vehicle. So if your jeep (the one being towed) is all wheel drive they are saying you have to disconnect the the rear drive shaft. However that is plain stupid. All you need to do is put the jeep (being towed) in nuetral and it will tow fine.
I won't lie to them about what vehicle you are using to tow with, your jeep will do fine and is definitely capable of pulling that load.
edit: The auto movers (the full auto trailer) are too heavy to be pulled by any jeep. they are 2300lbs empty weight.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #13 of 19 Old 11-12-2007, 12:49 PM
impuresoul2k3
I was going to say, when I picked up my Daytona, I had to use the car dolly with my ZJ because the full trailer was too heavy to pull with it loaded.
1993 Grand Cherokee Limited, 5.2L
Modified/Slightly Ported Kegger
Air hat spacer
Modified Throttle body
Flowmaster muffler
impuresoul2k3 is offline
post #14 of 19 Old 11-12-2007, 01:00 PM Thread Starter
tjsgrecc
thanks Indpndntece thats the answer i was looking for... looks like i am going to be renting a dolly.
02 WJ Laredo V8
tjsgrecc is offline
post #15 of 19 Old 11-12-2007, 01:26 PM
tubbyzj
1990 XJ Cherokee
well when i had my 88 xj i went to uhaul and got a trailer that was just under the biggest one they had i had the factory to package and they let me tow it all the way to pa i had the trailer it was i belive 2000lbs and then all my junk came out to be most likely 3100lbs and the jeep ran fine up hills and everything but braking wasnt fun but i got it to stop just plan your braking ahead of time all the extra weight effects braking
tubbyzj is offline
ESP & Tow/Haul button problems 07WKLtd WK Grand Cherokee & XK Commander Forum 3 11-24-2007 06:47 AM
No Tow Haul mode for diesel johnniebravo WK Grand Cherokee & XK Commander Forum 2 10-28-2007 09:56 AM
Towing U Haul Trailer btoz ZJ Grand Cherokee Forum 1 04-13-2007 07:09 PM
Tow Haul Mode Martin610 WK Grand Cherokee & XK Commander Forum 6 11-09-2006 02:38 PM
Towing JGC with a tow dolly J45p3r ZJ Grand Cherokee Forum 14 07-30-2005 08:16 PM
