pulling the front Bumper - JeepForum.com
post #1 of 6 Old 02-01-2013, 11:52 PM Thread Starter
papitt
.. So what do we do to pull the front bumper.. and It looks like the fog lamps are hooked to the an inter structure .. So I could remove the front bumper and then after swap out the front small square factory fogs. With something that has a bite......
papitt is offline
post #2 of 6 Old 02-02-2013, 12:05 AM
vonericsen
Remove the grill (3 screws)
The bolts for the foglight brackets are under it.
Then there are 3 black clips to remove here. (Pull the center head up then they slide right out). There are 3 of these on the bottom side where it connects near the skid/rad support too.
There are two or three clips holding the fender liner to the bumper cover to remove in the wheel wells.
Also remove the corner lights and turn signal lights since there it a spot under them holding the plastic cover in place.
Then it slides right off.
If something doesn't make sense I can take some pictures in the morning.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #3 of 6 Old 02-02-2013, 07:07 AM
KoreaZJ
1994 ZJ
After everything is removed, the cover will be dangling by two "fish hooks" near the ends.
Work the cover back and up a little, then forward over the hooks.
KoreaZJ is offline
post #4 of 6 Old 02-02-2013, 10:23 AM
ls1corik
My grill is four screws? I just had it off two days ago....
ls1corik is offline
post #5 of 6 Old 02-02-2013, 11:19 AM
dnuccio
the process for 93-95 ZJs is different than the process for 96-98 ZJs
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #6 of 6 Old 02-02-2013, 07:38 PM Thread Starter
papitt
Well I don't think I'll be removing the grill any time soon .. I've done something to my right arm .. Mostly in my colier bone area.. I lifted myself up from under either this Jeep or my Diesel Bronco this evening. I was working on both ..
Anyway there was this pop and a very sharp pain. Almost out me back on my *** . It hurts ..I'm sure it's not broke but maybe a bruised or pulled muscle. But it sure is hurting.
papitt is offline
