pulley noise - JeepForum.com
post #1 of 8 Old 02-20-2007, 07:36 PM Thread Starter
TheAngus
TheAngus's Avatar
pulley noise
if the idler pulley was bad what would the noise be, i hear a whining coming from the front end going up with rpm speed most noticable in first gear
thanks,
cory
1998 ZJ Limited 5.9L l Vortech Supercharged l SCT, 42lb Bosch, 255lph l Kolak 3" Exhaust w/ E-Cutout l KOR TB Conversion l Addco Swaybars F/R l JKS Rear TB l ORO U-Turn Steering w/ OME stabilizer l RE 4.5" Springs and Monotube Shocks l IRO Rear CAs l Kolak Ignition l Clayton Fronts l
TheAngus is offline
post #2 of 8 Old 02-20-2007, 08:04 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
It would be that noise. Take a look at the pulley. See if it has started to eat itself.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 8 Old 02-20-2007, 09:41 PM
kirsch98gc6
I love it when people answer their own questions
Josh
98 ZJ 4.0 8inch LA, 36 inch Iroks, Ected Lockd-Alloy USA chromo'd HP30, Aussie Lockd-Crown chromo'd-trussed D35, other goodies
kirsch98gc6 is offline
post #4 of 8 Old 02-21-2007, 04:15 AM
micifus
Original GC'er
micifus's Avatar
mine does it too how easy is it to replace that bearing?
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #5 of 8 Old 02-21-2007, 04:41 AM
greasefingers
greasefingers's Avatar
1994 ZJ
I wish I kept the bearing number! I bought two bearings (they are both the same on mine) then banged out the old ones with a large socket and then pressed the new ones in with a vice.
Yours are $ 15/ea at rockauto. The pulleys are constructed poorly on our Jeeps. So if you do a bearing swap, then do it with caution as these pulleys get distorted easily
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #6 of 8 Old 02-21-2007, 09:52 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
The pulley is bought as a unit. They are about 70$. Take the belt off, unbolt the old pulley and bolt the new one in. Make sure you don't strip the threads.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #7 of 8 Old 02-21-2007, 10:05 AM
WBowie
Hmm..I noticed a squeal comming from mine almost everytime I start it up. It goes away quickly..so I never paid it much though..now I will have to take a closer look.
WBowie is offline
post #8 of 8 Old 02-21-2007, 11:05 AM
greasefingers
1994 ZJ
Pulley unit $ 15 on rockauto. But two and replace the serpentine belt, if needed.
Cheers Steve
96 5.2 Squeling/ screaching noise from AC pulley dwills898 ZJ Grand Cherokee Forum 1 09-06-2009 02:16 PM
A/c pulley making noise crazydude2500 ZJ Grand Cherokee Forum 2 12-21-2008 08:57 AM
ZJ Fan Clutch Removal Help - Missing Pulley Bolts on Water Pump Pulley IdahoZJGuy ZJ Grand Cherokee Forum 10 07-11-2007 03:53 PM
AC pulley alivenkickin28 ZJ Grand Cherokee Forum 15 02-09-2007 06:11 PM
2000 Jeep GC Squaking noise.. Pulley? wowzer WJ Grand Cherokee Forum 8 04-26-2004 08:35 AM
