Pulley loose and sweaking bad - JeepForum.com
post #1 of 16 Old 07-22-2009, 08:58 PM Thread Starter
SGT Superman
SGT Superman's Avatar
My wife's 2000 Grand started squeaking today, The belt has moved back on the center pulley and the center pulley is loose when I take pressure off the belt.
So do I need a new pulley?
Any help is appreciated.
Now you know, and knowing is half the battle. G.I. Joe!
Green Jeep Club Member #174
GO COUGS!
SGT Superman is offline
post #2 of 16 Old 07-22-2009, 09:48 PM
elmer_fud
what pulley are you talking about?
if you are talking about the water pump and it moves in and out it needs replaced IMMEDIATELY. if you don't replace it it is going to go out soon and leave you stranded.
if it is an ideler or tensioner pulley you should still replace it soon. movement and squeaking indicate it is worn out
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 16 Old 07-22-2009, 09:54 PM Thread Starter
SGT Superman
Its the one in the picture, I think the crank pulley. From what I have found on another site it sounds like my harmonic damper needs replaced.
GO COUGS!
post #4 of 16 Old 07-22-2009, 10:00 PM
elmer_fud
where are you taking the picture from?
above or below or the side
the water pump is above the harmonic balencer. It could be the harmonic balencer needs replaced thoug
Brian
post #5 of 16 Old 07-22-2009, 10:20 PM Thread Starter
SGT Superman
From above, off to the side a bit. It is the very center pulley.
Edit: I think you are right, it is the water pump pulley.
GO COUGS!
post #6 of 16 Old 07-22-2009, 10:31 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Yea, that's the water pump in that picture.
If the pulley is movable, and the bolts are tight, you need to replace it NOW, before it lets go, and parts fling all over your engine compartment, taking out the radiator, and anything else the shrapnel bounces off of..
That belt doesn't look too good either. replace it at the same time.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #7 of 16 Old 07-22-2009, 10:55 PM Thread Starter
SGT Superman
Don't worry, it is parked and won't move again until it is fixed.
I have looked around a bit and can't find a write-up for the 4.0 2000 WJ water pump, but I did find a write up on stu-offroad for a TJ. That should be almost the same thing right?
Any special tools I need?
GO COUGS!
post #8 of 16 Old 07-22-2009, 11:03 PM
sandman
its going to be pretty much the same procedure for all 4.0s.
1993 Jeep ZJ. 4.0
sandman is offline
post #9 of 16 Old 07-22-2009, 11:05 PM
sandman
go buy a haynes manual and this link may help.
http://jeephorizons.com/phpbb/viewtopic.php?t=14090
1993 Jeep ZJ. 4.0
sandman is offline
post #10 of 16 Old 07-22-2009, 11:39 PM Thread Starter
SGT Superman
Thanks for the link sandman.
The silver lining in this is that my TJ has recently started to leak antifreeze from an unknown location, but because of this i now know it is coming from the water pump, looks like I will be busy the next few days.
GO COUGS!
post #11 of 16 Old 07-29-2009, 09:49 AM Thread Starter
SGT Superman
I changed out the water pump in my wife's WJ and she is complaining about the oil pressure and temp fluctuating slightly, and it never did it before I replaced the water pump. ANy ideas of what that could be?
I replaced the water pump in my TJ and all is perfect.
GO COUGS!
post #12 of 16 Old 07-29-2009, 01:17 PM
elmer_fud
how much is it fluctuating?
the oil pressure will fluctuate a bit based on the engine speed
my temperature also fluctuates a bit depending on whether I am stopped or accelerating or something. It moves slowly though.
Brian
post #13 of 16 Old 07-29-2009, 03:25 PM Thread Starter
SGT Superman
She says the goes from about 40 to 50 I think, and the temp goes up about 5 - 10 deg. But it has only happened since I replaced the water pump.
I don't think its a big deal, but I wanted to ask incase someone knew something.
GO COUGS!
post #14 of 16 Old 07-29-2009, 04:19 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
oil pressure is ok, it is supposed to fluctuate with rpms, 40 at idle or below 2krpms is good, 50 at acceleration is good as well.
the temp is probably fluctuating because the coolant is moving correctly again.
i'd suggest you have a ride in it for a while to see what it's really doing. it's been my experience that even the most intelligent women have a difficult time relating pertinent info to the men they expect to fix things.
ratmonkey is offline
post #15 of 16 Old 07-29-2009, 07:41 PM
elmer_fud
I wouldn't worry about that much fluctuation from the gages. I second you drive her jeep and see what is going on
Brian
XK Water Pump Pulley Loose;leak fuzzard WK Grand Cherokee & XK Commander Forum 2 02-17-2009 08:09 AM
ZJ 4L Crankshaft Pulley Loose Bricolage ZJ Grand Cherokee Forum 5 02-06-2009 02:18 PM
ZJ Fan Clutch Removal Help - Missing Pulley Bolts on Water Pump Pulley IdahoZJGuy ZJ Grand Cherokee Forum 10 07-11-2007 03:53 PM
AC pulley alivenkickin28 ZJ Grand Cherokee Forum 15 02-09-2007 06:11 PM
Crank Pulley HELP!!!! 4weeln ZJ Grand Cherokee Forum 5 03-02-2005 09:56 PM
