pulled up code p1391 and p0132 - JeepForum.com
post #1 of 8 Old 09-05-2009, 06:53 PM Thread Starter
jim75
pulled code p1391 and p0132. does anyone know these?
jim75 is offline
post #2 of 8 Old 09-05-2009, 09:29 PM
WJRON351
check this,Jeep Grand Cherokee WJ - Diagnostic Trouble Codes
those are codes for wj but maybe they are the same
WJRON351 is offline
post #3 of 8 Old 09-05-2009, 11:58 PM
WiCkeDuDe
WiCkeDuDe's Avatar
P1391 is a inconsistant losee of camshaft position sensor input or crankshaft position sensor input- Loss of the Cam Position Sensor or Crank Position sensor has occurred.
Most likely the camshaft position sensor - common issue.
p0132 -O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
Oxygen sensor input voltage maintained above normal operating range.
Bad O2 sensor
Would be the one in the exhaust manifold
WiCkeDuDe is offline
post #4 of 8 Old 09-06-2009, 09:36 AM Thread Starter
jim75
are thoes the same for a zj?
jim75 is offline
post #5 of 8 Old 09-06-2009, 10:13 AM
WiCkeDuDe
WiCkeDuDe's Avatar
obd2 codes are the same for all obd2 vehicles.
post #6 of 8 Old 09-13-2009, 01:10 PM Thread Starter
jim75
where is the camshaft position sensor located?
jim75 is offline
post #7 of 8 Old 09-13-2009, 04:35 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Back on the driver side bell housing if I remember right.
I Have WJ Stuff for Sale
post #8 of 8 Old 10-11-2009, 06:36 PM
hockeyfreak2091
no cam shaft is in the distributor. a black plate that the one wire hooks to. crankshaft is the bell housing.
hockeyfreak2091 is offline
P0132 code, why? Mark Humphries ZJ Grand Cherokee Forum 0 07-01-2007 07:54 AM
Just pulled code... CBlakeNS ZJ Grand Cherokee Forum 11 05-21-2007 12:21 AM
Pulled code 24. TPS JeepZJ94 ZJ Grand Cherokee Forum 2 01-12-2007 09:04 PM
Replaced sensors, still get code P1391 wizjeep97 ZJ Grand Cherokee Forum 1 12-14-2004 12:18 PM
