PS System HELP! - Page 2 - JeepForum.com
post #16 of 20 Old 06-22-2011, 06:12 PM
MaintMech
Old and in the way
MaintMech's Avatar
Remember there is more fluid in the whole system than in the reservoir. Right now you're just filling the system up. Keep doing what you've been doing and the leak will show.
Frankly I'd replace the steering box and the hoses. Pump is suspect too from being run while empty.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #17 of 20 Old 07-10-2011, 12:41 AM Thread Starter
FlamingRain
The overall objective here is to get the power steering to function again, but I can't do a complete box replacement.
Remember- the power steering no longer works at all, and I've narrowed it down to the box, the reservoir moves fluid out, but it leaks out- which I don't have the resources to replace (I'd have to buy one, and have someone install it as I haven't ever performed any kind of mechanical replacement on this scale. a big $$ grabber).
I wanted to see if there was a way to stop the leak to get the power steering to work again. I've read that LUCAS stop leak is pretty good at stopping a leak in the system - one thing I'm a bit sketchy on. It says it fixes most 'Rack and Pinion' problems. From what I know, ZJ's don't use Rack and Pinion, they use a reciprocating ball / gearbox configuration. If I used the stop leak would it seal the gearbox leak on the pitman shaft? Would it be more time worthy and money-worthy to rebuild (new seals) on the pitman shaft?
2wd can really get you places you can't get out of without 4lo. - Ratmonkey
FlamingRain is offline
post #18 of 20 Old 07-10-2011, 12:52 AM
Virmagicus
Virmagicus's Avatar
You need to find out if and where it is leaking from. You said you added fluid and then the level dropped again. Wipe everything down and keep adding more fluid until you find out where the leak is.
Jeff
Virmagicus is offline
post #19 of 20 Old 07-10-2011, 12:55 AM Thread Starter
FlamingRain
I'll look again- but I'm more than sure it's where the the pitman arm connects to the box. Of all of the steering components I inspected, it was the only thing that wasn't clean, and it was totally caked in fluid.
post #20 of 20 Old 07-10-2011, 01:09 AM
Virmagicus
Virmagicus's Avatar
Just wipe everything down (hoses,connections,steering box,pump reservoir, etc)and then add fluid. Then you will be certain where the leak is coming from.
Jeff
which 4WD system do I have?! Brudus WK Grand Cherokee & XK Commander Forum 3 10-01-2010 05:21 AM
Service 4x4 System AND Service Electonic Brake System...? TatorTodd WK Grand Cherokee & XK Commander Forum 0 12-25-2009 08:49 PM
Nav System Jmar8 WK Grand Cherokee & XK Commander Forum 8 02-29-2008 08:08 AM
Nav/CD System will123ab ZJ Grand Cherokee Forum 6 06-13-2006 10:24 PM
How do I get Vehicle Entertainment System turned on in my Nav system? JeepSam ZJ Grand Cherokee Forum 10 06-03-2005 03:46 PM
