programming preset seats - JeepForum.com
post #1 of 4 Old 07-17-2011, 10:15 AM Thread Starter
19YJ91
I have a 97 limited and there are buttons for the power seats to adjust automatically. How do I program them? Also every time I use the key fob the mirrors and seat moves how do I program this? thanks in advanced.
19YJ91 is offline
post #2 of 4 Old 07-17-2011, 12:35 PM
JeeperV8
Thats all part of the set seating, I'll confirm when I can get my book out of the truck (I'm at work) but I believe you hold set until set lights up on the info center, set the poisons of seat, mirrors, and preset stations of radio (if stock) then push one of the set buttons to store all of this.
JeeperV8 is offline
post #3 of 4 Old 07-17-2011, 12:47 PM
gothchick
I was reading at some point (a thread is on this forum) that if the mirrors and seats are not holding their settings, sometimes it's a result of dirt getting in behind the outside driver's mirror. Something to do with the electrical connection not being solid. Fubars the system up...
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #4 of 4 Old 07-17-2011, 01:51 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
look at the driver's door. there's a panel that has a 1, 2, and set button.
look at the back of your fob for the number it is set to.
set your seat and mirrors to where you want them. hold the set button till blinking. then press the button that corresponds to the fob you're using.
the mirrors not holding their settings is the sensor. the memory module breaking power is the only reason the seats would revert to home position when the fob is pushed. unless it's reverting to the other set point that the fob doesn't do.
ratmonkey is offline
PCM Programming 99 WJ netzwerk1 WJ Grand Cherokee Forum 4 06-25-2015 12:08 AM
ECU programming for 3.7? CoreyZ WK Grand Cherokee & XK Commander Forum 8 02-23-2011 06:37 PM
Memory Preset Mirrors Freaking out? klwong1 ZJ Grand Cherokee Forum 18 06-27-2009 03:17 PM
MyGig Preset Issue acsimon WK Grand Cherokee & XK Commander Forum 21 01-18-2009 11:08 AM
Key programming 89luderSi ZJ Grand Cherokee Forum 6 01-06-2009 03:55 PM
