Programming new key fob for 1996 Grand Cherokee - JeepForum.com
post #1 of 6 Old 08-17-2005, 04:42 PM Thread Starter
llabnad
Can someone tell me how to program a new key fob into my 1996 Grand Cherokee. I bought one on Ebay and need to know how to make it work.
llabnad is offline
post #2 of 6 Old 08-17-2005, 04:53 PM
shelbymopar89
This may help, had some problems myself recently....
http://www.jeepforum.com/forum/f13/programing-door-lock-unlock-key-fobs-184624/
Brent
89 Daytona Shelby
89 Daytona Shelby Parts Car
03 2500 Ram Q.C. HEMI
shelbymopar89 is offline
post #3 of 6 Old 08-17-2005, 05:20 PM
Meerkat
You cannot. The process is actually programming the Jeep to recognize the RKE fob, rather than the other way around. You'll have to take it to your friendly neighborhood Jeep dealer (or someone with a DRB scantool) to have the Jeep programmed. While you are there, they can also program how your doors unlock, whether or not they automatically lock, horn honk when you set the alarm or not, headlights on with wiper, and a few other features.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 6 Old 11-27-2013, 07:56 PM
zamd24
PROGRAM INSTRUCTIONS JEEP 2 BUTTON REMOTES
Up to 4 transmitters can be programmed into the receiver at any given time.
All transmitters to be used on a vehicle must be programmed during this procedure.
(1) Open the driverís door and leave it open during the programming process.
(2) Move the mechanical door lock lever on the driverís door to the LOCK position.
(3) Insert the ignition key and turn it to the RUN position. (Do not start the vehicle.)
(4) After turning the ignition key to the Run position aim the transmitter at the receiver and press the LOCK (right) button for 5 seconds. Once the receiver accepts the programming the door will unlock.
Move to Step 5 If you have more than one transmitter you are going to use with this vehicle. Move to Step 6 If only one Jeep remote is used.
(5) If additional transmitters are to be used on the vehicle each must be programmed during the programming sequence. (Up to 4 transmitters can be programmed to a vehicle) To program additional transmitters Return the mechanical door lock lever on the driverís door to the LOCK position and aim the next transmitter at the receiver and press the LOCK (right) button for 5 seconds. Again when the receiver accepts the programming the door will unlock. Repeat step 5 until all transmitters have been programmed.
(6) When all transmitters have been programmed to the receiver, the ignition must be turned off and back on within 20 seconds after programming the last transmitter. When this is done, only the transmitters that were programmed to the vehicle during this procedure will operate the locks.
zamd24 is offline
post #5 of 6 Old 11-28-2013, 10:41 AM
Camaro16
That's for pre-96 jeeps - won't work.
Camaro16 is offline
post #6 of 6 Old 11-28-2013, 03:35 PM
Mickey_D
Meerkat has it right.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
New 1996 Grand Cherokee subliminal ZJ Grand Cherokee Forum 1 02-24-2009 04:51 PM
1996 Grand Cherokee - Where is the VIC? muzicman82 ZJ Grand Cherokee Forum 12 09-08-2007 10:32 AM
Please help grand cherokee 1996 ANDY31259 ZJ Grand Cherokee Forum 1 10-08-2006 05:59 AM
1996 Keyless Programming CIoaked ZJ Grand Cherokee Forum 9 09-07-2006 06:38 PM
1996 Grand Cherkokee remote programming jrenegade13 ZJ Grand Cherokee Forum 3 06-01-2003 01:33 AM
