Problems shifting into 4Low... - JeepForum.com
post #1 of 18 Old 08-05-2009, 07:18 PM Thread Starter
jopolly3
Ok boys heres the deal the girlfriend just got a 1997 ZJ Limited 5.2L (giving you the stats because I don't know what t-case that equates to, Quadra-trac is it a 249?) I was playing around with it earlier and decided to see how it shifts into low. I put it in N, pulled it straight back into low, let it roll forward a little then put it it D. IMMEDIATELY it started making a grinding noise so I quickly threw it in P after a second I put it back in N and shifted into 4Hi again and it was perfectly fine...
Now I know when I use to put my WJ in 4Low when I first started wheeling it would sometimes bind up and give me problems but after repeated use it started working smoothly. Seeing that this is my girlfriends new Jeep and I don't want to blow up her t-case doing something wrong I figured I asked before I just kept shifting until it worked. Any ideas?
thanks in advance
joe
Joe
2013 JKU Rubicon 6spd: ARB Dana 44 covers F&R, Expedition One front bumper & swaybar skid, Hella driving lamps, JKS adjustable track bars F&R, MBRP SS off-road exhaust, OME HD springs and shocks, OME relocated SS, Rock Hard 4x4 gas tank skid, Rock Hard 4x4 oil pan skid, Rock Hard 4x4 rock sliders, Rock Hard 4x4 transfer case skid, Spidertrax wheel spacers, Superwinch LP8500 Gen 1
2002 Subaru WRX: Cobb intake, Mishimoto aluminum radiator, Kartboy short throw shifter and bushings
1960 CJ-6: Never ending project rig
Build Threads:
JKUR -
CJ6 -
WJ -
"BFG makes some good rubbers, if they sold condoms I'd buy them" -Owen Horner
jopolly3 is offline
post #2 of 18 Old 08-05-2009, 07:35 PM
squashman702
1994 ZJ
Not sure if it's the same with the WJ, but you're supposed to be rolling in N at 3-5 mph to shift into low. Did you check the linkage? It might be out of adjustment and therefore not letting the TC drop all the way into low.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #3 of 18 Old 08-05-2009, 08:34 PM Thread Starter
jopolly3
yeah i'll crawl under there this weekend and check it out
Joe
Build Threads:
JKUR -
CJ6 -
WJ -
jopolly3 is offline
post #4 of 18 Old 08-05-2009, 09:39 PM
SnowLeopard
I know that with my 242 transfer case I have some trouble getting it to lock in low sometimes. You have to make sure engages good before going into drive, or it'll be unhappy. I don't imagine you wouldn't notice this. The VIC should notify you if it's not fully engaged. It just won't light up "4-wheel-low", but again, I don't imagine you need that to know if you're in it or not. I have had those doy moments though where I didn't get it fully engaged and felt like an idiot. It happens.
SnowLeopard is offline
post #5 of 18 Old 08-05-2009, 10:09 PM
Travis873o
just reiterating the previous comment, but you'll feel it when it's fully engaged, you can almost feel like a notch when you got it right. just pull hard and fast and you should get it. it happened to me too. just got show it who's boss. lol
Travis873o is offline
post #6 of 18 Old 08-06-2009, 06:39 AM Thread Starter
jopolly3
Haha you see I don't know everything... The WJ doesn't have a light that notifies you that it is in low. Tomorrow I will try again and this time I will pull until I see the light...
Joe
Build Threads:
JKUR -
CJ6 -
WJ -
jopolly3 is offline
post #7 of 18 Old 08-06-2009, 07:02 AM
Tigggger
...my 2000 WJ had a light on it that told me it was in 4-Low.
Tigggger is offline
post #8 of 18 Old 08-06-2009, 07:05 AM Thread Starter
jopolly3
Really? I mean you get the little orange tick mark next to the shifter but nothing pops up that says "4Low" on my 2000...
Joe
Build Threads:
JKUR -
CJ6 -
WJ -
jopolly3 is offline
post #9 of 18 Old 08-06-2009, 07:37 AM
Tigggger
It was a 4-Low light on the bottom right corner where all the gauges are located. It glowed either Orange or Green. But pretty much all you need to know how to tell if it's in 4-HI or 4-LOW is to compare the RPMs while accelerating. You'll see a dramatic difference. I'm still learning but that's something I noticed right away. God I missed the roar of that I-6 in 4-LOW, you'd swear it was an 18 wheeler. Makes ya go hard lol.
Tigggger is offline
post #10 of 18 Old 08-06-2009, 08:05 AM Thread Starter
jopolly3
Haha no I can tell when the Jeep is in 4Low I just couldn't tell when it was fully engaged before putting this ZJ in drive. My WJ always has a nice smooth shift into low you throw it in D and feel that extra push trying to over power the brakes... I love that 4.7
Joe
Build Threads:
JKUR -
CJ6 -
WJ -
jopolly3 is offline
post #11 of 18 Old 08-06-2009, 08:10 AM
gmp211
Try throwing it in reverse, roll a couple feet, then drive. Sometimes that helps.
2002 WJ - Forest Green
gmp211 is offline
post #12 of 18 Old 08-06-2009, 08:16 AM
SnowLeopard
Actually, it's more than a light. On the VIC in front of the shifter you'll see the image of the Jeep and four wheels, and in 4-low all the wheels will light up to show it's in 4wd. Then it will light up a notice that says 4 Low. It's easy to miss that last hitch in getting it to lock. I've done it in some pretty slippery situations, too. A bad time to miss!
I'm sure you'll get it to lock though now that you know. The Jeep just wants you to work for it.
post #13 of 18 Old 08-06-2009, 08:41 AM Thread Starter
jopolly3
"... AND KNOWING IS HALF THE BATTLE!" haha awesome thanks guys I'll see how she does
Joe
Build Threads:
JKUR -
CJ6 -
WJ -
jopolly3 is offline
post #14 of 18 Old 08-06-2009, 11:24 AM
Mickey_D
If the ZJ has the 3 position 249 transfer case (4Hi-N-4Lo), all you need to do to shift it (when it's everything is working correctly) is to put it in neutral on the transmission and shift straight through to 4Lo on the transfer case. Do not pause in neutral on the transfer case. It should shift just as smooth as the transmission.
http://www.boomspeed.com/bofh1968/je...nsfer-case.wmv
I even made a video of it to show what it's like. Take a peek.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #15 of 18 Old 08-06-2009, 02:19 PM
skunked_once
Check to make sure that the linkage arms are all in the correct place. My 94 GC with the 249 has a socket in the transmission and one shaft from the linkage has to fit in there. My TC wouldn't shift into 4LO because the shaft had come out of the socket.
skunked_once is offline
shifting problems vredenburg08 ZJ Grand Cherokee Forum 3 10-05-2009 11:18 AM
'97 ZJ LTD shifting into 4LOW richiscool ZJ Grand Cherokee Forum 12 02-26-2009 02:54 PM
4WD shifting problems compcrasher86 ZJ Grand Cherokee Forum 0 01-07-2009 03:47 PM
Shifting Problems Trail Man WK Grand Cherokee & XK Commander Forum 1 04-03-2007 12:19 PM
Shifting Problems 4zlove ZJ Grand Cherokee Forum 1 11-15-2002 11:10 AM
