Problems with buying used... Please help - JeepForum.com
post #1 of 9 Old 03-11-2014, 01:06 PM Thread Starter
91Jeepdude
We bought a 98 ZJ 5.2 4x4 (Quadratrac) w/ 146,xxx miles for a reasonable price and it seamed to have little wrong... BUT...
My First concern is, after having it for about 2 weeks, after driving it (usually after a short run), when I put it in park and turn off the engine, it sounds off a thud/popping type noise and the whole thing will shake as if it were in gear and quickly pumping the breaks. This kinda freaks me out.
Secondly, when turning aprox. 3/4 to full turn, I get a noise like a whining and I get heave resistance that will slow me down to a stop. I do know that I need to replace the driver's side wheel-hub assembly. I have the part, I just haven't put it in yet.
Has anyone else had this problem? May it just be the hub assembly? Or does it sound more of a problem with the Diff?
Lastly, it's more annoying then just being a problem (yet), but I have a leak somewhere, and I can't find where it is coming from. I check the basic fluids (coolant, steering, oil, trans) regularly, and there's no visible signs of a leak. the leak is on the passenger's side of the Jeep and is yellow in color, but no distinguishing smell to it.
Are there any "common" leaks in the 5.2L ZJ's? Ideas on troubleshooting?
I'm sure I will have more questions in the future, but it's a Jeep.... I doubt they'll be any soon.
91Jeepdude is offline
post #2 of 9 Old 03-11-2014, 01:17 PM
xcaliber81
Problem 1 could it be like its still trying to run if thats the case id say timing
Problem 2 could be the viscus coupler.
xcaliber81 is online now
post #3 of 9 Old 03-11-2014, 01:24 PM
LowBudgetZJ
Cannot help you with first 2 but maybe the last. I pulled my window washer fluid reservoir the other day when replacing my shocks. Then I set it up on the fender and jacked up the driver side I noticed a puddle of green fluid behind front passenger tire. I freaked out thinking it was anti freeze but no smell and then noticed my window washer fluid tank was nearly empty.
There must be an overflow or pressure relief on the passenger side????? Hopefully that is the source of your leak. BTW no leak before or after I reinstalled the tank and fluid to all three nozzles.
98 ZJ 4.0 42RE NP242
75 CJ5 232 T14 D20.....STOLEN
LowBudgetZJ is offline
post #4 of 9 Old 04-08-2014, 06:36 PM
elijahpr
Your second problem sounds similar to mine. When I try to make a sharp-ish turn, my Jeep has a lot of trouble doing it. It bounces, is loud as hell, and needs more gas to keep moving. If that's the case for you, it's the viscous coupler. I just kinda deal with it, and plan on swapping in a 242 or 231 when I get the chance and money to.
1998 Grand Cherokee TSi (5.2, 44re)
3-inch Rough Country Lift
31" BFG Rugged Terrains
elijahpr is offline
post #5 of 9 Old 04-08-2014, 06:41 PM
RemingtonRifles
the second problem is the viscus coupler mine is out and i just deal with it.
RemingtonRifles is offline
post #6 of 9 Old 04-08-2014, 07:01 PM
PolkaPower
Just take out the front drive shaft until it gets fixed.
PolkaPower is online now
post #7 of 9 Old 04-08-2014, 07:20 PM
elijahpr
Can you do that with a 249? I've read both ways.
elijahpr is offline
post #8 of 9 Old 04-08-2014, 07:51 PM
shaban
Safe to do on post-96, not safe on pre-96 (will roll in park and overstress the VC)
shaban is offline
post #9 of 9 Old 04-09-2014, 04:50 AM
elijahpr
Awesome! I've got a 98 GC and the VC is done for. This'll let me wait till fall to do the swap.
elijahpr is offline
help needed , leaking fluid , problems , steer stop
