Problem w/ factory tow harness - JeepForum.com
post #1 of 9 Old 07-18-2011, 09:05 AM Thread Starter
jjeep
1998 WJ
I have a 98 jeep grand cherokee larado with the factory tow harness. Problem is I have no turn, or stop lights, just tail and marker. I have replaced all relays. I am not seeing any voltage on the pink/black stripe wire. Where the tow harness connects to the full harness at the full harnes side. I suspect this wire is the power that the relay is connecting. I can't locate the pink/blk in any fuse box.
The 50 AMP tow/mux fuse in the engine comp. is also good.
The breaker in the harness also has continuity.
At my factory connector -
Blu/Red - Tail lights
Grn - Left Signal
Tan - Right Signal
Wht/Tan - Brake
Light Blu - Electric Brake
Blk - Grnd
Pink/Blk - Power for lights thru relay ? (I have no voltage here)
What is the routing for the Pink/Blk? Test points?
Is there a fuse or relay I am missing?
Thanks this is driving me nuts!
jjeep is offline
post #2 of 9 Old 07-18-2011, 09:17 AM
Foundrydude
The factory tow light module for your truck should be behind the driver's side cargo area panel, it combines the turn/stop lamps for the trailer. Are your trailer brakes factory, or does the truck have an aftermarket controller?
There's an extra on the round 7 pin design (purple). Some people use it for reverse lights. But you don't have to use it at all and not all trailers have reverse lights anyway. Is that your pink/black?
I am confused by you listing 7 pins but having one pin for stop, and two others for turn. At the trailer those signals have been unified by the module mentioned previously, and only occupy two pins.
If you're lacking turn/stop, then green and tan are what you should be looking at. If the truck's got voltage at green or tan with signals/brakes on then your problem's in the trailer. Lots of times when a friend calls me over to sort out his truck's trailer wiring we end up fixing the trailer.
Here's a link that shows standard color coding for trailer wiring.
http://www.etrailer.com/faq-wiring.aspx
good luck!
Foundrydude is offline
post #3 of 9 Old 07-18-2011, 02:05 PM Thread Starter
jjeep
1998 WJ
Hey Thanks for the response.
The rear driver side panel is where I found the 3 relays I replaced.
The harness is factory.
No aftermarket controller.
Colors for signals into the relays -
Grn - Left Signal (turn)
Tan - Right Signal (turn)
Wht/Tan - Brake (stop)
These are working I have voltage when the signals are activated.
The wires that leave the relays and go to the trailer are not showing voltage at the relay when they should.
There should be a supply wire that is hot going into the relay, when the signal wire (Lt Grn - left turn) has voltage it throws the relay switch and the voltage from the supply wire heads to the lights. I believe the pink wire supply that voltage and it is not hot but I don't know why? I think this is the same circuit that come in on the pink/blk from the jeep vehicle harness which is also not hot but should be (I think) or I am completly wrong.
The ground is good to the tailgate latch so thats not the problem.
jjeep is offline
post #4 of 9 Old 07-18-2011, 02:17 PM
Foundrydude
You may have a bad tail lamp converter module. They're available aftermarket for $25 if you don't mind soldering. Fair number of people on this board have em fail.
post #5 of 9 Old 07-18-2011, 02:37 PM Thread Starter
jjeep
1998 WJ
Where is the tail lamp converter module?
Thanks
jjeep is offline
post #6 of 9 Old 07-18-2011, 02:42 PM
Foundrydude
I believe the module itself is behind the cargo area service door, but on your 98 it plugs into wiring that's behind the passenger side cargo panel. Black box, bout the size of a pack of smokes. A quick search for trailer wiring should pull up several threads.
Note that 95-earlier had a different module that plugs in at a different point. So take your advice or junkyard parts from a 96-up.
Good luck!
post #7 of 9 Old 07-18-2011, 03:00 PM Thread Starter
jjeep
1998 WJ
Is there anyway to test it?
jjeep is offline
post #8 of 9 Old 07-18-2011, 03:10 PM
Foundrydude
I think if there's correct power going in, but not correct power coming out.....that's the test.
post #9 of 9 Old 07-18-2011, 04:46 PM Thread Starter
jjeep
1998 WJ
Okay.
I searched but have not come up w/ much info on a tail lamp converter module.
Just to confirm - This is different from the three relay pack I found behind the driverside rear panel? Which is also about the sz of smokes. I am really getting tired of taking the interior apart! Who's idea was it to put these on opposite sides?
Thanks for the info.
jjeep is offline
harness , pink , relay , tow
Help please with installation of factory trailer harness DarrylFlynn WK Grand Cherokee & XK Commander Forum 20 02-13-2009 01:55 AM
wiring harness / factory amp not2high ZJ Grand Cherokee Forum 4 07-14-2008 12:20 PM
WTB factory trailer harness WJ Btm495 ZJ Grand Cherokee Forum 11 04-03-2008 09:08 PM
Non Factory Tow Harness 4 My JEEP PresTx82 ZJ Grand Cherokee Forum 5 06-13-2007 02:50 PM
Factory hitch and wire harness pbesanson ZJ Grand Cherokee Forum 2 02-03-2002 11:25 PM
