Problem with starting Jeep! 93 GC - JeepForum.com
post #1 of 7 Old 11-09-2008, 11:02 AM Thread Starter
cammoman
Hi everyone,
I just bought a 1993 Grand cherokee and I am having trouble starting up with the key. I am able to start the car by sending a positive feed from the battery to the line that goes to the starter (I exposed some copper on the starter line and I use a jumper). But here's my problem I can't start the car with the key by turning it. So my first thought was the anti-theft system, I do not have the keyless remote so I tried to disable the security system by grounding the purple wire with the yellow stripe behind the door panel but no luck. Any suggestions???
Oh and when I start the car by sending a positive feed to the starter line I have the key in the ignition turned to the on setting.
cammoman is offline
post #2 of 7 Old 11-09-2008, 11:15 AM
colinzj
2006 WK
What happens when you turn the key to start?
The VTSS (security system) doesn't prevent the starter from running—it cuts off the fuel supply. If your problem is that the starter won't run, the factory security system isn't part of the equation. Some aftermarket alarms have a starter kill, but unless you've got an aftermarket keyfob, that's probably not it either.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #3 of 7 Old 11-09-2008, 11:43 AM
Tiggerrrrr
Since you've ruled out the starter and battery, next step is the ignition switch.
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #4 of 7 Old 11-09-2008, 11:47 AM Thread Starter
cammoman
When i turn my key to start the car all of the dashboard lights turn on but when I try to crank the car to engage the starter, nothing happens. No clicking, nothing.
cammoman is offline
post #5 of 7 Old 11-09-2008, 12:06 PM
JrMechanic
Tumbler, very common problem in 93's. When my brother owned mine, he had the same problem, ended up running two switches, one for the starter and one for accessories for awhile, then he just replaced the whole column with a 94.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #6 of 7 Old 11-09-2008, 03:33 PM
colinzj
2006 WK
Definitely sounds like the ignition switch should be your next step.
colinzj is offline
post #7 of 7 Old 12-27-2011, 01:08 PM
bigray122
1993 XJ Cherokee
I bought and replaced a new switch. I put in the key and it spins all the way forward to the run position. Are one or both of the tabs on the switch not hitting or seating in something properly?
bigray122 is offline
01 Jeep GC Limited WJ Starting Problem DJHile WJ Grand Cherokee Forum 15 12-14-2013 09:14 PM
Starting problem on a zj bds93zj ZJ Grand Cherokee Forum 1 10-20-2009 04:26 AM
Problem with Jeep not starting 4x4jeepguy ZJ Grand Cherokee Forum 21 04-25-2008 02:11 PM
Problem starting! MY Jeep wont turn over!!! coolest_Stan ZJ Grand Cherokee Forum 18 12-13-2005 07:52 PM
GC Starting Problem... John N ZJ Grand Cherokee Forum 6 05-15-2005 11:25 AM
