Problem solver balljoints?? - JeepForum.com
post #1 of 24 Old 05-24-2011, 08:09 AM Thread Starter
LILGRIZZ
Well looks like I may be due for new balljoints. I noticed they make a problem solver balljoint, what problem do they solve? If they are for lack of caster adjustment I just installed all new adjustable ca's to solve that issue. Any words of wisdom out there?
thanks, Jason
LILGRIZZ is offline
post #2 of 24 Old 05-24-2011, 08:13 AM
MineRunnerZJ
That's just a Moog brand. I have heard that Moog has become hit and miss on quality. I put in Spicer upper and lowers and they have performed well for over two years and have put up with quite a beating.
Jeepless.......for now. YJ build coming soon...
SOLD - 1998 Jeep Grand Cherokee 5.9L Some go fast goodies, JK Moabs 255/75R17 BFG M/Ts, MX-6s, 4'' RE Lift - Super Ride Adj. control arms, Addco's, JKS trackbars/discos..... Kolak Exhaust/Ignition, SCT tuned!
ARB Bull Bar
SOLD - 99 TJ 4.0L AX15 -
6" Rubicon Express Springs/Disco's, Clayton's Long Arm w/ triangulated 4 link, Ford 8.8 4.56 gears. JB SS SYE, Tom Woods Driveshafts. Poison Spider Rocker Knockers
K&N Intake, Flowmaster Cat and 50 series, Custom Front/Rear Bumpers with Warn XD9000i.
Rollin on 35" BFG A/T's
SOLD - 93 ZJ 4'' RE lift, 32 BFG MT tons of other goodies!
NoVA Jeepers
MineRunnerZJ is offline
post #3 of 24 Old 05-24-2011, 08:17 AM
ajmorell
ajmorell's Avatar
I'm pretty sure the problem solver are the ones that will allow for adjustable caster or camber (depending on how you install them). Adjustable CA's will let you dial in caster but on a lifted vehicle caster and pinion angle are not mutually exclusive. Having adjustable BJ's will allow you to get some caster back (a couple degrees max) and still have a decent pinion angle.
ajmorell is offline
post #4 of 24 Old 05-24-2011, 09:32 AM Thread Starter
LILGRIZZ
I do have a 3.5" lift and was wondering about pinion angle and caster. I don't know how much of an issue it is with only 3.5" of lift though.
LILGRIZZ is offline
post #5 of 24 Old 05-24-2011, 09:43 AM
ajmorell
ajmorell's Avatar
Shouldn't be, at 4.5" of lift I was able to get the pinion angle dialed in and still maintain 4* of caster
ajmorell is offline
post #6 of 24 Old 05-24-2011, 09:45 AM
speedbucket
they are just offset, which is considered "weaker" by most
it is something i would consider at 5" or more of lift to have the caster slightly better with the correct pinion angles. (help with a "dead" spot in the center of steering)
they are "problem solvers" bc it gives you the ability chang your camber and caster angles a little depending on the orientation they are installed.
ouple on the torsion bars to level it out. they helped me get my camber under control.
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #7 of 24 Old 05-24-2011, 10:18 AM
rdrbssr11
Moog or spicer is what I use on all the jeeps I wrench on. Don't go with a cheap no name brand or expect to replace them every year or so. The better name brands usually get installed and I never have to touch them again.
-95' grand cherokee w/ 5.2. ARB & xd9000. IRO 4.5" w/ 33's. 8.8 & HP 30 w/ 4.10's both aussie locked and some other goodies.
-97' grand cherokee w/ 4.0. stock.
rdrbssr11 is offline
post #8 of 24 Old 05-24-2011, 11:01 AM
ajmorell
ajmorell's Avatar
Torsion bars? Not on a ZJ....
ajmorell is offline
post #9 of 24 Old 05-24-2011, 11:04 AM
JrMechanic
XRF for ball joints...
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #10 of 24 Old 05-24-2011, 12:06 PM Thread Starter
LILGRIZZ
I use ONLY Moog on everything I drive.
LILGRIZZ is offline
post #11 of 24 Old 05-24-2011, 12:08 PM
speedbucket
Phone deleted line
"On my old truck"
89 Dakota.
post #12 of 24 Old 05-24-2011, 12:29 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
then you should consider and upgrade to spicer or xrf.
moog has been re-boxed chinese crap for about the last 8-10 years now. most jeep owners are reporting less than 12k on a set these days.
ratmonkey is offline
post #13 of 24 Old 05-24-2011, 12:36 PM
ajmorell
ajmorell's Avatar
XRF will be my next set as well. Spicers are getting harder and harder to find.
ajmorell is offline
post #14 of 24 Old 05-24-2011, 12:38 PM Thread Starter
LILGRIZZ
I've heard of Spicer but not XRF, who sells them?
LILGRIZZ is offline
post #15 of 24 Old 05-24-2011, 12:45 PM
freakinheep89
I have ~25k on my XRF's after installing them last year. they are doing great with no play whatsoever. And that includes a years worth of wheeling trips.
And i got all 4 for about $110 shipped.
You have to cal them directly.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
Offset balljoints! -cAcHe- ZJ Grand Cherokee Forum 2 12-04-2009 08:17 PM
which balljoints? -cAcHe- ZJ Grand Cherokee Forum 14 10-28-2008 03:05 PM
balljoints Derek33 ZJ Grand Cherokee Forum 42 07-18-2008 07:59 PM
wj balljoints painted600rr ZJ Grand Cherokee Forum 4 05-09-2008 03:18 PM
balljoints jeeporvis ZJ Grand Cherokee Forum 11 04-18-2008 09:30 PM
