Problem reconnecting rear track bar - JeepForum.com
post #1 of 5 Old 10-06-2013, 12:38 PM Thread Starter
keastland
I just installed new taller coils and shocks. To do so, I removed the sway bar links and rear track bar (disconnected on the high side).
I have the new springs and shocks installed, connected the sway bar links, but can not get the rear track bar to go far enough into the bracket to get the bolt in.
Is there a trick to this? I apologize if there's already a thread about this, but I plan on going out of town this weekend so I have limited time to get this done. I did do a quick search, but didn't see anything right away.
Thanks in advance for the help!
keastland is offline
post #2 of 5 Old 10-06-2013, 12:40 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Ratchet strap is your friend.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 5 Old 10-06-2013, 01:00 PM Thread Starter
keastland
I thought of that. I guess I'll try that tonight when I get home.
Thanks.
post #4 of 5 Old 10-06-2013, 03:14 PM
dave_dj1
How tall did you go? If you went too high you may have to get a different track bar or bracket.
Wheel it like ya stole it!
dave_dj1 is offline
post #5 of 5 Old 10-06-2013, 03:47 PM
WhiteOut
WhiteOut's Avatar
Leave the frame side disconnected, with the wheels on the ground you're going to shake the back of the Jeep around and let it find it's center. Then you adjust the track bar so it just slides in.
WhiteOut is offline
