Problem with quad tail light mod? - JeepForum.com
post #1 of 1 Old 09-23-2003, 02:12 PM Thread Starter
ecrab3
ecrab3's Avatar
OK, something started to happen to it. When the park lights are on, all 4 come on, but when I brake, the pass side lights both go bright, but the drivers side, only the original top light goes on. The lower one goes completely dark. It lighst back up to the lower dim setting after I release the pedal. WHat could it be?
Ok, this is what I have checked...
Changed all bulbs..duh. Nothing changed.
Changed the extra light plug....no change
Checked the wires, I didnt crimp, I soldered all of them together for faster response and max brightness....no bad connections.
Has this happeded to anyone else with the mod? Could it be a bad relay or do you think I harmed the factory wiring? Any suggestions on how to get it to work right again? I did work correctly at one time, so im not sure what changed.
TIA
eddie
Eddie Crab3
'97 XJ
Nuttin Special
ecrab3 is offline
Tail light problem FakeName ZJ Grand Cherokee Forum 3 08-06-2009 10:38 AM
Problem With Tail?brake Light semperfismhs ZJ Grand Cherokee Forum 8 01-22-2009 12:09 PM
Left Tail Light is Very Dim- Electrical Problem? pCarson92 ZJ Grand Cherokee Forum 10 11-20-2008 01:06 AM
Tail Light and Instrument light problem t_guenther ZJ Grand Cherokee Forum 0 09-18-2008 07:27 AM
brake/ tail light problem darnelled ZJ Grand Cherokee Forum 11 06-13-2005 08:16 AM
