Problem with Jeep not starting - JeepForum.com
post #1 of 22 Old 04-10-2008, 07:50 PM Thread Starter
4x4jeepguy
Ok, i have tryed everything i can think of, gets spark from the coil to the distributor but no spark coming out of the distributor, the whole thing is new, been trying 2 fix the issue for awhile now with no luck, btw is a 93 jeep grand , with the inline 6
4x4jeepguy is offline
post #2 of 22 Old 04-10-2008, 08:09 PM
tsconver
2003 WJ
take teh distributor cap off and try turning the rotor, or have someone crank the engine and see if the rotor turns when it cranks. Maybe you had a distributor gear shear off and the rotor is not spinning.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
A few goodies
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
2006 Red Liberty
Wife's ride, pretty stock
tsconver is offline
post #3 of 22 Old 04-10-2008, 08:16 PM Thread Starter
4x4jeepguy
Turns, all the way made sure that its in timing
post #4 of 22 Old 04-10-2008, 08:20 PM
tsconver
2003 WJ
new rotor and cap? Any carbon burns or traces inside teh distributor, you sure you got the right cap and rotor?
A few goodies
2006 Red Liberty
tsconver is offline
post #5 of 22 Old 04-10-2008, 08:21 PM Thread Starter
4x4jeepguy
Yes new, and no burns still looks new
post #6 of 22 Old 04-10-2008, 08:24 PM
tsconver
2003 WJ
how do you know you got spark fro coil and not from teh plug wires.
A few goodies
2006 Red Liberty
tsconver is offline
post #7 of 22 Old 04-10-2008, 08:28 PM Thread Starter
4x4jeepguy
Current Tester, getting fire from the coil, but nothing coming out of the dis.
post #8 of 22 Old 04-10-2008, 08:51 PM
tsconver
2003 WJ
maybe you are not getting enough current / volts. Did you try putting the coil wire close to a ground? It should be a nice blue spark able to jump a nice sized gap. If so connect it tothe distributor and try each plug wire the same way. They should each produce a clean blue spark over a big gap. If it won't jump a gap fromt eh coil try a new coil.
A few goodies
2006 Red Liberty
tsconver is offline
post #9 of 22 Old 04-10-2008, 08:56 PM Thread Starter
4x4jeepguy
coil does do a nice jump, but the distributor does nothing
post #10 of 22 Old 04-10-2008, 09:00 PM
tsconver
2003 WJ
well if you are getting spark from the coil wire and nothing from the plug wires either you got bad plug wires or a bad cap and rotor, or the wrong cap and rotor. Check the resistance of the plug wire, do it withthe cap attached to them and measure the resistance from the plug end tothe post insidethe rotor. I would bet you got teh wrong cap or rotor, you try putting the old one back on?
A few goodies
2006 Red Liberty
tsconver is offline
post #11 of 22 Old 04-10-2008, 09:11 PM Thread Starter
4x4jeepguy
I have tryed with the old one, c the issue started when trying 2 move,the jeep used 2 go thru crank case sensors, i had taken it 2 a shop and they said they had 2 guess the ecm, replaced it still the same issue, i been working on this for issue for well over a year
post #12 of 22 Old 04-10-2008, 09:14 PM
tsconver
2003 WJ
might be cheaper and faster to take it to a professional
A few goodies
2006 Red Liberty
tsconver is offline
post #13 of 22 Old 04-10-2008, 09:16 PM Thread Starter
4x4jeepguy
lol, i did ecm was there guess, they traced all wires and all, but ecm did nto fix it so
post #14 of 22 Old 04-10-2008, 11:53 PM
Virmagicus
Virmagicus's Avatar
Any codes ? CPS ?
Jeff
Virmagicus is offline
post #15 of 22 Old 04-11-2008, 12:02 AM Thread Starter
4x4jeepguy
355 but thats all, honestly i lost my manual so i don't know what it means
01 Jeep GC Limited WJ Starting Problem DJHile WJ Grand Cherokee Forum 15 12-14-2013 09:14 PM
Problem with starting Jeep! 93 GC cammoman ZJ Grand Cherokee Forum 6 12-27-2011 01:08 PM
another starting problem jason0682 ZJ Grand Cherokee Forum 2 06-11-2008 06:35 PM
Problem starting! MY Jeep wont turn over!!! coolest_Stan ZJ Grand Cherokee Forum 18 12-13-2005 07:52 PM
Problem Starting gutz03 ZJ Grand Cherokee Forum 4 02-24-2005 11:57 AM
