07-14-2005, 02:26 PM
#1
my grand cherokee 1988 won't start...
i dont know why, but it shows that my oil and water tanks are empty, which is not !
is there a wire disconnected? or is there a fuse burned? can someone give me advice plz?
P.S: there is some kind of wire dosconnected in the far top left corner in my trunk. I tryed to find where it belongs to, without success...
PLZ HELP !
- Vlad
07-14-2005, 02:32 PM
#2
Mr. Hyde!
You have water tanks? You probably mean you engine temperature. You'll only have oil pressure when the engine is on. Both measure temperature and pressure, not level so unless the engine is on there won't be any readings there.
Do the interior lights come on? Does the radio work? Do the vents blow?
Yes there could be a wire disconnected or a bad fuse but won't know w/o more information.
If the engine doesn't even try and turn over at all: make sure the Jeep is in park and the steering wheel isn't locked into position (should be able to turn it with feeling of resistance, not a hard stop.
-Ryan
07-14-2005, 02:35 PM
#3
radio and vent work absolutely fine ....
can you precise plz what is the steering wheel? I'm not very good in these expressions...
thz alot for your help
07-14-2005, 02:44 PM
#4
Mr. Hyde!
Uhm, asking what the steering wheel is?
If I remember correctly it won't start if the steering wheel is in the locked position. It gets like this when you have the Jeep off and turn the wheel too much in one direction, it will lock. To unlock it turn the wheel in the direction that doesn't feel like it has a hard stop while trying to start the Jeep...
-Ryan
07-14-2005, 02:47 PM
#5
I will try that and I will come back in a sec
#6
You're messin' with us, right?
If you're seriously don't know I'm not surprise your mom took her keys with her
Hello all!
I have a huge problem there...
my mom went to another country and took the master key with her ....
Did you brake into your moms car yet?
07-14-2005, 02:57 PM
#7
-Ryan
This is Hilarious!!!
Only on the jeepforum
07-14-2005, 03:01 PM
#8
Arlo
Is that a pair of Doc Martin steel toes?
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
#9
jeez.... steering wheel was NOT the solution... anywayz , it was free....
I am suspicious about that wire that is disconnected... it has two holes (contacts)... it is situated in the very far top left corner....
I checked the fuses : THERE ARE LOTS!!! maybe one of them is missing ... can any of you guys tell me how they are supposed to be there, or any othwer suggestions?
ps: when i turn the key to its final position, i have the impression that there are no power that is going to the starter at all, and all I hear is some clicks on my left side...
PLZ HELP ME!!
07-14-2005, 03:03 PM
#10
Mr. Hyde!
Want me to post some parts of other things for you zaq123? I can find all sorts of things/parts of cars for you...Perhaps a chocolate jeep:
07-14-2005, 03:15 PM
#11
plz guyz help
07-14-2005, 03:17 PM
#12
Mr. Hyde!
Originally Posted by greasefingers
Arlo
Uhm, sure...Just found that pic on the internet....I didn't actually go out and take a pic of a steering wheel (I have to work...err, slack off I mean)
-Ryan
07-14-2005, 03:24 PM
#13
Mr. Hyde!
Battery that is almost dead? If it doesn't have enough power it won't even try and turn the starter. How old are you? You supposed to be driving this car? Why not call your mom and ask her what you have to do to start it?
-Ryan
07-14-2005, 07:12 PM
#14
-Ryan
According to his profile, he's 20, but I must admit I am suspicious...
Vlad, it sounds like you have a dead battery. I seriously doubt a disconnected wire at the liftgate is keeping the Jeep from starting.
I really think you need to give your mom a call. It's obvious the vehicle is hers and she would know much better than us what it takes to get it started.
HTH
Warren
Black 1996 5.2L ZJ Limited
07-14-2005, 07:29 PM
#15
There was a 1988 Grand Cherokee?
2002 WJ - I6
BB+UC 3.5" lift | K&N FIPK | Armor/Tow points |
265/75R16 Cooper Discoverer S/Ts
