Problem. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Problem.
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Unread 06-27-2012, 01:14 PM   #1
James5295
Problem.
Ok I just went trailing for my first time
But on my road home, my left wheel started to click and knock as i turn. My buddy said it could be the CV joint. It only happens when i turn left. Help :/
James5295 is offline   Reply With Quote
Unread 06-27-2012, 01:32 PM   #2
squazz
thats a good place to start
squazz is offline   Reply With Quote
Unread 06-27-2012, 01:39 PM   #3
pincheburro956
cv shaft. you get the left one, i already bought the right one, and we can share warranty info..hahahaha
"Not a single **** shall be given."
99 WJ, 2" BB, 245/75/16 Falken Rocky Mountain ATS.
pincheburro956 is offline   Reply With Quote
Unread 06-27-2012, 01:47 PM   #4
squazz
I actually have a new short side (left one) sitting in the garage I dont need
Unread 06-27-2012, 06:38 PM   #5
James5295
Donations are always welcome
Unread 06-27-2012, 08:37 PM   #6
squazz
50% off
Unread 06-28-2012, 07:41 AM   #7
James5295
50% off
Im jacking her up today, if i end up needing it i will get back to you
Unread 06-28-2012, 11:00 AM   #8
James5295
After careful investigation. and 10 minutes of hard work and dedication. we found out that it is my passenger side cv joint. and its $75 at my local junk yard. so field trip.
96 Jeep Zj Limited v-8 5.2l Auto.
Unread 06-28-2012, 11:28 AM   #9
squazz
they are $100 new most JY's charge 10-15$ $75 from a JY is high but the again you are in NY
Unread 06-28-2012, 11:33 AM   #10
corndogduff
I'd say if you're gonna go the JY route, pull BOTH shafts from an XJ that doesnt have CV joints and be done with that hassle. CV brings teh fail.
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline   Reply With Quote
Unread 06-28-2012, 01:05 PM   #11
James5295
I'll see what I can do.
Please tell me someone knows how to do it. Please lol. Cause I can afford to pay someone ATM
Unread 06-28-2012, 03:13 PM   #12
gabrod72
Best to get ones with the larger u-joints from a ZJ. IIRC some Xjs have the smaller ones like wranglers.
_______________________________________________
WARNING: Lo barato sale caro (Cheap things often lead to more expense)
gabrod72 is offline   Reply With Quote
Unread 06-28-2012, 06:21 PM   #13
James5295
Who has changed one before and can tell em how to do i. cause im doing it tomorrow.
Unread 06-28-2012, 07:37 PM   #14
squazz
search function is your friend
http://www.jeepforum.com/forum/f13/r...y-how-1374495/
Unread 06-29-2012, 08:51 AM   #15
James5295
Alrite boys im going in.
