Pressure switch under my battery? - JeepForum.com
post #1 of 7 Old 04-23-2013, 04:38 PM Thread Starter
a70eliminator
I continue to reveal new oddities on my 5.9 like what is the purpose of the pressure switch under my battery, it appears to spring load open when battery is removed?
a70eliminator is offline
post #2 of 7 Old 04-23-2013, 05:08 PM
durango-bob
2006 WK
It's a temp sensor. I guess it's to prevent the battery from heating up too much when charging.
durango-bob is offline
post #3 of 7 Old 04-23-2013, 06:46 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Kinda. The switch sends a signal to the pcm which contains the voltage regulator. This signal is dependant on battery temp. Don't really know how accurate the system is cause mine sits at 14v, hot,cold,or otherwise.
Originally Posted by HighLonesome
coralman is offline
post #4 of 7 Old 04-24-2013, 06:42 AM
Uniblurb
Uniblurb's Avatar
Your voltage should be dropping down from 14V coralman after the battery warms up. Higher voltage when cold and drops gradually as it warms up. Next time you have your battery out disconnect the wiring harness to the sensor and you should be reading between 9K-11K ohms at the sensor 2-wire connection. Supposed to replace the sensor if not reading within this range. Just thought I'd pass this along.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #5 of 7 Old 04-24-2013, 11:44 AM
coralman
coralman's Avatar
Will do Uni, thanks!
coralman is offline
post #6 of 7 Old 04-24-2013, 10:21 PM
Uniblurb
Uniblurb's Avatar
No problem coralman and good luck!
Uniblurb is offline
post #7 of 7 Old 08-04-2013, 12:24 PM
Rockbasses
Just found mine today too! Thanks for the info from this thread. I was just wondering?!
Rockbasses is offline
