Powering a CB - JeepForum.com
post #1 of 4 Old 08-19-2011, 07:57 AM Thread Starter
JakeK
Powering a CB
what would be the easiest way to get power to a CB?
JakeK is offline
post #2 of 4 Old 08-19-2011, 08:15 AM
little_Jeep
Easiest, or best?
If you want CB to be powered by key, use hot wire for cig lighter. If you want CB to have power all the time, and you want to less static, run power & ground wires to battery directly. Just be sure that your power wire is fused as close to the battery as possible.
little_Jeep is offline
post #3 of 4 Old 08-19-2011, 07:25 PM
Derph
1994 ZJ
I just used power pole connecters when I cut the rear cig lighter, which is hooked up by the stock amp. no noise
Derph is offline
post #4 of 4 Old 08-19-2011, 08:06 PM Thread Starter
JakeK
I ended up just cutting through the firewall and connecting it to the battery
I Do Not Go Where The Path Leads. Instead I Create My Own Path....And Leave A Trail...It's a JEEP thing
JakeK is offline
Powering another amp off of infinity amp? whatpavment? ZJ Grand Cherokee Forum 16 01-31-2008 09:41 PM
5.9L powering off randomly dundun ZJ Grand Cherokee Forum 7 12-16-2007 04:14 PM
coolant fan not powering on with ac jeremypittman ZJ Grand Cherokee Forum 8 08-21-2006 07:28 PM
