-   -   Powering a CB (http://www.jeepforum.com/forum/f13/powering-cb-1254774/)
JakeK 08-19-2011 08:57 AM
Powering a CB
what would be the easiest way to get power to a CB?
little_Jeep 08-19-2011 09:15 AM
Easiest, or best?
If you want CB to be powered by key, use hot wire for cig lighter. If you want CB to have power all the time, and you want to less static, run power & ground wires to battery directly. Just be sure that your power wire is fused as close to the battery as possible.
Derph 08-19-2011 08:25 PM
I just used power pole connecters when I cut the rear cig lighter, which is hooked up by the stock amp. no noise
JakeK 08-19-2011 09:06 PM
I ended up just cutting through the firewall and connecting it to the battery
The time now is 02:01 AM.
