Power Windows wont work - JeepForum.com
post #1 of 22 Old 02-25-2003, 01:06 PM Thread Starter
DIXIE
DIXIE's Avatar
Has anyone had any problems with their power windows not working? I think it is an electrical problem but I don't know where to start. All the fuses are good... Any ideas? Thanks
85 CJ-7, 258, 69K, all original except carb and chrome
DIXIE is offline
post #2 of 22 Old 02-25-2003, 02:25 PM
moabster
moabster's Avatar
2011 WK
Check this thread
and this one
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
post #3 of 22 Old 02-26-2003, 05:49 AM
blackbelt
blackbelt's Avatar
Another common trouble spot is the power window switch assembly.
2001 XJ Sport
2007 Caliber R/T AWD
2000 Subaru Forester
2006 Scion xB
1987 VW Wolfsburg Cabriloet
1969 SAAB 96 V4
blackbelt is offline
post #4 of 22 Old 02-28-2003, 08:52 AM Thread Starter
DIXIE
DIXIE's Avatar
Thanks for the help. There were 5 cut wires in the driver side door wiring assembly. Took me an hour or two to fix but no big deal. Thanks again! DIXIE
DIXIE is offline
post #5 of 22 Old 03-05-2003, 04:10 PM
pHaZe5unIt1
heres what I found inside my door loom when my windows wouldnt work...
2004 wrangler 2.4L
pHaZe5unIt1 is offline
post #6 of 22 Old 02-26-2004, 01:21 PM
acerboca
Power Window Problems
I am a new member to the JeepForum.com website, and i too am having problems with the power windows on my 94 ZJ. I can put down all of the windows from my drivers seat but no one else can put down their windows from their seat. If someone could help me that would be fantastic. Thank you again for lookin at my Post and please reply if you can help.
acerboca is offline
post #7 of 22 Old 02-26-2004, 03:13 PM
Meerkat
It sounds silly, but is the master switch locked? There is a button on the driver's panel that when pressed locks all the other switches out, so that only the driver's switch works.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #8 of 22 Old 02-27-2004, 07:57 PM
acerboca
I know it sounds funny but no. they dont work from any other windows only from the driver side. So if you have any tips that would really help me out. thank you for trying and lookin at my post.
acerboca is offline
post #9 of 22 Old 02-27-2004, 08:18 PM
Stocker
Don't give up on this suggestion yet - the master switch might be bad, or the wiring at the switch could be bad. Probably worth checking.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #10 of 22 Old 02-28-2004, 06:49 AM
madmanfrommars
madmanfrommars's Avatar
Yeah I have a 94 too and the window controls keep going in and out.
I did some of my own rewiring because they dealer would charge a fourtion for labor on something like this. They work somewhat. I can control them all from my controls, and the passanger window has some difficulity but it works for the most part.
madmanfrommars is offline
post #11 of 22 Old 10-10-2005, 05:13 PM
jmeix
power locks not working
my power locks will unlock from all doors, and remote on my 93 gcl, but will not even attempt to lock from any of those, or even make a noise. when I push the lock switch, although it doesn't lock the doors, it does turn on the alarm
jmeix is offline
post #12 of 22 Old 10-10-2005, 05:51 PM
Stocker
Ah, an old thread brought back again from the grave!
The "unlock" circuit will be on a different wire than the "lock" circuit. Have you checked door connector as mentioned in moabster's links?
Stocker
Stocker is offline
post #13 of 22 Old 02-28-2008, 09:03 PM
ro2thego35
this happened to mine a while back
i was stuck in some mud and just stomping on the pedal haha
i ended up blowing a fuse and a lot of the electrical stuff in the car stopped working, including the windows an the locks, check your manual for the fuse that regulates these things and try changing it, if that doesnt work then i got nothing
ro2thego35 is offline
post #14 of 22 Old 12-17-2008, 03:51 AM
antjay
my 96 zj has a similar problem,occasionaly the switch pannel on the drivers door stops working.no windows,mirror adjustment,or central locking.i can still raise or lower the windows using the individual switches on the passenger doors ,and central locking locks all doors except for the drivers door when activated by the key fob.
my auto electrician had a quick look at it when fixing an unrelated problem and couldn't find any obvious reason for the problem.
i have since been told by another zj owner that his does the same.his solution is to disconect the earth lead at the battery , and then reconect it.this apparently "fixes"the problem untill the next time.
i can't vouch for this as the problem hasn't resurfaced since i spoke to him, but it might be worth a try.
antjay is offline
post #15 of 22 Old 12-17-2008, 09:05 AM
j.love
j.love's Avatar
1994 ZJ
Good lord this is an old thread.
It's like talking to somebody threw a time machine, and if you have ever done that you know how hard that can be.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
Door lock,mirror,windows wont work allmopar WJ Grand Cherokee Forum 33 06-26-2015 06:21 PM
97 ZJ Passenger side windows wont work Toliver09 ZJ Grand Cherokee Forum 0 04-27-2009 09:38 AM
Power windows don't work speedluvn ZJ Grand Cherokee Forum 3 02-17-2009 07:05 PM
Power windows work....sometimes 93DDQZJ ZJ Grand Cherokee Forum 6 07-14-2006 10:39 PM
All Power Windows Don't Work?????? Clay454 ZJ Grand Cherokee Forum 13 12-31-2003 04:15 AM
