Power Windows Broken? Short? - JeepForum.com
post #1 of 7 Old 10-02-2003, 02:20 PM Thread Starter
DrewT
I just noticed that my power windows won't roll down with any of the switched (drivers included), except the front passenger side. I can't find anything else that has stopped working. Keyless entry, power locks, power mirrors, it all works, except the power windows. I couldn't find a fuse for them, but there probally is. Can anyone give me some advice? '96 GC Laredo (ZJ)
It's really weird...
-Drew
DrewT is offline
post #2 of 7 Old 10-02-2003, 05:59 PM
Stocker
Instead of a fuse, there's a circuit breaker to the right of the glovebox, in the door jamb area behind a plastic cover. Your owners manual will tell you which one. But I'm betting it's bad wiring at the driver's door connector. Pull back the rubber boot and have a look. If you see broken wires, fix 'em. Make sure the torx screw holding the connector is snug. Good luck!
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
post #3 of 7 Old 10-02-2003, 06:44 PM Thread Starter
DrewT
Banged on the controls a few times...it works...for now. I'll open it up and check the wiring...do you know, by chance, what size torx screw it is?
-Drew
DrewT is offline
post #4 of 7 Old 10-02-2003, 11:41 PM
Swamp Boy
Swamp Boy's Avatar
You may as well invest in a cheap set of torx screwdrivers..
From T10 to T45 you will need them all eventually...
Carl
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #5 of 7 Old 10-03-2003, 05:07 PM Thread Starter
DrewT
Alright...how do you get to the wiring???
-Drew
DrewT is offline
post #6 of 7 Old 10-03-2003, 06:16 PM
Stocker
To the switch? I dunno - I guess remove the inner door panel.
To the door jamb connector? See my first reply above.
Stocker
Stocker is offline
post #7 of 7 Old 10-03-2003, 08:50 PM Thread Starter
DrewT
How do you remove the door panel to access the switches??
Thanks
-Drew
DrewT is offline
Help with ZJ power windows Just dune it ZJ Grand Cherokee Forum 5 01-25-2010 12:40 AM
5.2 power loss after short drive flybop ZJ Grand Cherokee Forum 2 03-05-2009 03:50 PM
2004 Lerado - Driver Power Lock & Power Windows lbi2000 ZJ Grand Cherokee Forum 3 10-20-2008 04:58 AM
Broken Windows Steve and Will ZJ Grand Cherokee Forum 1 10-16-2007 11:57 PM
Power Locks/Power Windows on Passenger Side ccox ZJ Grand Cherokee Forum 2 07-09-2005 09:46 AM
