Power window switch turns on ABS light, what? - JeepForum.com
post #1 of 4 Old 06-16-2010, 09:22 PM Thread Starter
tommy54
I have a 94 ZJ, which had the usual driver door wire harness problem. I fixed it once with butt connectors, and when it broke again I pulled it and soldered the harness back together, replacing any wire that was too brittle to hold up much longer. I bench tested for continuity while moving the harness around and it was absolutely perfect. When I installed it in the jeep only a few windows went down, and only one would go back up. The locks don't work. If I hit the window switch for one of the windows that doesn't work, the ABS light comes on. What is that about? I thought the ABS light only came on if one of the abs sensors grounds out. Any thoughts on this?
tommy54 is offline
post #2 of 4 Old 06-17-2010, 08:01 PM
ZeeJay1997
since i do not have the diagram, all i can suggest is you check for bent pins in the connector under the dash, i'm assume you disconnected it.
ZeeJay1997 is offline
post #3 of 4 Old 06-17-2010, 09:44 PM Thread Starter
tommy54
harness itself bench tests perfect for continuity on all wires, even if I move the harness around. The pins are all fine, I looked at them right away. I'm really curious about why the ABS light would come on. I can understand if there's a short somewhere, but how does that affect the ABS light? Since the harness tests fine, and there aren't any bent pins, what could be happening?
tommy54 is offline
post #4 of 4 Old 06-24-2013, 05:57 PM
wtb300
1994 ZJ
3 years and no solution. I guess I'll tinker till it burns
wtb300 is offline
Does your power mirror adjuster switch light? JAC1502 ZJ Grand Cherokee Forum 4 12-11-2009 09:12 AM
XK power window switch bfr WK Grand Cherokee & XK Commander Forum 0 06-29-2009 06:23 PM
Power Window Switch tsprairie700 ZJ Grand Cherokee Forum 3 06-06-2008 07:18 PM
Power Window Switch rndthm ZJ Grand Cherokee Forum 4 04-05-2006 08:52 PM
Power window switch lights? zeketorrence ZJ Grand Cherokee Forum 2 02-07-2006 05:53 PM
