Power window switch problems (not the master lockout one) - JeepForum.com
post #1 of 5 Old 06-17-2013, 05:22 PM Thread Starter
93zjer
I have two switches that dont work. I tried to rebuild them, they were burnt and pitted inside on the contact points. This has worked for me b4 on another ZJ but these two are too bad (even tried filling in the pits with solder) one left rear one right front.
I can find used ones easily but new are 86+ dollars. Any cheaper source for these switches new?
STANDARD MOTOR PRODUCTS Part # DS1171
93zjer is offline
post #2 of 5 Old 06-18-2013, 12:22 PM
eagsc7
1994 ZJ
Junkyard Run! While there, look at other ZJs and remember that most all parts from a 93-95 ZJ will work for you! Switches should run you less than $20 each... if not together!
eagsc7 is offline
post #3 of 5 Old 06-18-2013, 05:27 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Cheap ebay also. I've seen them for less than 86.00
Originally Posted by HighLonesome
coralman is offline
post #4 of 5 Old 06-18-2013, 06:48 PM
riot1987
I could buy at least 50% of a jeep for 86 dollars! Hit up a junkyard dude
Build thread^^
riot1987 is offline
post #5 of 5 Old 06-18-2013, 08:57 PM Thread Starter
93zjer
I can get used ones for $15 but they're used.
93zjer is offline
