Quantcast Power Window? (READ FAQS) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Power Window? (READ FAQS)
Old 06-02-2005, 06:12 PM   #1
SteveA83
I have a 97 GC Limited all the windows don't work. I pulled off my drivers door panel and pass door panel. I have power on the tan wire at both switches. And I have ground on the black wire at both switches. I tried swapping door switches and BCM but no good. I can manually power up and down the drivers side windows at the switch harness and manually do the pass. side from the pass. switch harness. I checked to make sure the circuit breaker was good. Anybody have any suggestions. Is there another ground that I am missing or is the only ground in the door harness the one that goes to the window switch. Please Help ASAP (its getting hot around here).
SteveA83 is offline   Reply With Quote
Glock Forum
