Power Washed Engine - Check Engine Light on Now - JeepForum.com
post #1 of 32 Old 04-13-2008, 12:25 PM Thread Starter
Davis87YJ
Ok,
So I power washed the engine yesterday at the car wash, didn't cover anything, but was attempting to stay away from spraying the electrical stuff.
Immediately after the check engine light is on now. I've driven it about 10 times since then and the light only stays on 1/2 the time. I turned it off at a few stoplight, started it back up and the light goes off.
Well I check the codes today and all sorts of crap is flashing. It looks to be codes 12, 21, 51, and of course 55. Any idea what I did or an easy fix for it?
Thanks,
-TIM-
Davis87YJ is offline
post #2 of 32 Old 04-13-2008, 12:27 PM
The27Jeenyus
see now where you went wrong was using a power washer, use a garden hose on a light setting so it doesnt douse the engine with water
Zach
Originally Posted by Willy36 View Post
icequeen's got something sticky in her hair from some dude named zach
The27Jeenyus is offline
post #3 of 32 Old 04-13-2008, 12:30 PM Thread Starter
Davis87YJ
Obviously looking back that wasn't a good idea, I sprayed the engine with engine bright stuff before hand and didn't want to spay that stuff off in my driveway, hence why I went to the car wash.
I should add I had no codes a few weeks ago when I bought the thing.
Pulled this from another site:
12 Battery input to PCM disconnected during last 50 key starts.
21 Problem in the oxygen feedback circuit.
51 Lean condition is indicated.
So whats the chances the engine just needs to "dry out" a bit?
post #4 of 32 Old 04-13-2008, 12:34 PM Thread Starter
Davis87YJ
Another thing to add.
I put in a bottle of the Marvels' Mystery Oil in the tank at the car wash too. It doesn't pass emissions and a buddy swears by the stuff saying it will revive the engine a bit. It's got 155k miles, didn't have any codes at the time and I didn't want to start replacing catalytic converters and O-2 sensors just to try and get it to pass It's a non daily driver that will see use 2 weekends a month if I'm lucky.
post #5 of 32 Old 04-13-2008, 12:37 PM
BzJeep
BzJeep's Avatar
Those codes were retreived from the message center on the main dash gauges correct? P0012, P0021 etc.?
According to WJJEEPS,
Your problem most likely lies within the Cam-Shaft Position (Over Retarded/Over-Advanced) and/or the O2 Sensor #1 Heater Control Circuit (high/low banks). Both of which are on the bottom passenger side of your engine compartment. Chances are you drowned them out. You may try to get down there w/ an air hose and carefully spray them off. You can use a Haynes or Chiltons manual to find out exactly what part it is. If it's not the parts themselves then you may have actually drowned part of the computer modules and so it's becoming confused now, hehe.
Good luck!
2008 Metropolitan Gray Mazda3S Sport
2001 Steel Blue Grand Limited *SOLD*
1993 Forest Green Wrangler *SOLD*
Green Jeep Club Member #16
BzJeep is offline
post #6 of 32 Old 04-13-2008, 12:37 PM
alivenkickin28
never never never use a power washer to clean your engine..
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #7 of 32 Old 04-13-2008, 12:46 PM
BzJeep
BzJeep's Avatar
I wouldn't say never... just make sure you cover electrical stuff and only use it for targeting grimy areas on your block, other than that... a simple spraynozel on your garden hose w/ some good degreaser will be just fine. I know it takes time but hand washing the other more fragile things is best.
BzJeep is offline
post #8 of 32 Old 04-13-2008, 12:49 PM Thread Starter
Davis87YJ
I did the turn ignition on/off 3 times to get the check engine light to flash those codes.
Yeah I'm pretty sure I doused that area pretty good, I was just trying to get the engine itself, trying to avoid, the battery, alternator, pcm, fuze box all that stuff. But if it was down low I probably sprayed it good.
post #9 of 32 Old 04-13-2008, 02:33 PM
mailforjon
mailforjon's Avatar
2005 WK
degreaser + garden hose =
degreaser + power washer =
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
post #10 of 32 Old 04-13-2008, 02:35 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
Why do people see a need to clean under the hood of a Jeep?... just let it get dirty!
2013 FR-S
BlaineWasHere is offline
post #11 of 32 Old 04-13-2008, 05:02 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
i've power washed under the hood of many vehicles very often and not had an issue with the electronics.
ratmonkey is offline
post #12 of 32 Old 04-13-2008, 05:24 PM
Windowsrookie
Good for you.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline
post #13 of 32 Old 04-13-2008, 06:55 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
Common sense says to keep the high pressure off the electronics & connectors.
TIM:
You may have forced water into the CPS or other sensors' connector, which means you will have to open the connector and blow the water out since it's now "sealed" in there.
Windowsrookie: Are you trying to up your post count with those very snappy snippets?
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #14 of 32 Old 04-13-2008, 07:07 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
Good luck!
i dont know if it makes a difference or not, but he has a ZJ.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #15 of 32 Old 04-13-2008, 07:08 PM
Valkyrie0002
2009 JK Wrangler
In the days of points and distributor type ignitions you had to be careful with the garden house. We used to wrap the distributor with a plastic bag and silicone the plug wires when running in water. High pressure in the engine compartment will force water into fittings and connectors it would normally never access. I have had no issues with the garden hose and I would never use a power washer.
Valkyrie0002 is offline
Ocassional bucking/loss of power... check engine light ERICH ZJ Grand Cherokee Forum 12 06-20-2011 12:35 PM
97 ZJ Lost power, check engine light nitwit ZJ Grand Cherokee Forum 0 08-06-2008 08:07 PM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
check engine light, engine losing power kemicalburns ZJ Grand Cherokee Forum 21 05-27-2005 01:49 PM
Washed engine, now stalling with engine light on skaer ZJ Grand Cherokee Forum 3 07-14-2003 11:40 AM
