Power Steering Reservoir Replacement? - JeepForum.com
post #1 of 7 Old 10-06-2012, 07:36 PM Thread Starter
jeeper772
Was replacing the hoses (return and high pressure) and the "nipple" that comes off the reservoir to the return hose broke off. Pump was fine, was replacing the high pressure line (leak) and decided to replace all hoses/assembly. Can you just replace the reservoir? Without getting a new pump as well? My pump is fine, and probably overdue for a new one, but I'm broke and don't want to spend the $60 on a whole new pump/reservoir, although I probably should. Any ideas or quick fixes/hints/tips? I assume JB weld would not be a good idea on this particular piece, being plastic (and I assume high pressure on the way back into the pump reservoir?)
I should probably just get a new one, but I can only find rebuilt ($60) with reservoir. If I do anything, I'll at least replace the belt as well. Live and learn my friends, but it's hella fun. (Except when you're broke and need a car!)
1995 Grand Cherokee Orvis Edition 5.2L V8 175,000 miles
1995 Wrangler 4 cylinder 90,000 miles
jeeper772 is offline
post #2 of 7 Old 10-06-2012, 07:44 PM
PolkaPower
I dunno dude, I messed with my power steeering and my harmonic balancer broke. Took two weeks to find the problem.
PolkaPower is online now
post #3 of 7 Old 10-06-2012, 08:03 PM
kachink
Looks like the reservoir is part #52006395 on www.moparpartsoverstock.com
$62.93
I think you'd be better off getting a rebuilt pump with a reservoir.
kachink is offline
post #4 of 7 Old 10-07-2012, 07:24 PM
Oldfrog
2007 WK
I did the same thing and have learned to hate that nipple as a result. I went to a u-pullit junkyard, bought an entire PS unit off a 98 ffor $20 and swapped out the reservoir. It slides off after sliding the keepers off.
Pay attention to the o-ring.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #5 of 7 Old 10-10-2012, 11:34 AM Thread Starter
jeeper772
That's right, best bet is to get one from a junkyard. Pretty easy to swap out the reservoir, just a couple of clips. Couldn't get to one, so I just bought a new pump and reservoir at Oreillys for $60 (have to turn in the core). Might as well since I already had the whole unit off and was replacing both hoses as well. Pretty easy as well, once you get around the rusted on bolts (Lots of patience and PB blaster) and tight space to get to the bolts on the pump (keep trying, I tried a few different tools and got it off without having to pull the radiator/fan shroud). Thanks again guys.
post #6 of 7 Old 10-10-2012, 11:50 AM
minimika2008
I would just get the new pump and reservoir. Just did this on mine 2 weeks ago. I didn't realize how good my jeep could be on steering until the whole new pump went on. And it was my reservoir that was messed up as well. It's 3 bolts on and off so it's not to bad either! Only bad thing that happened to me is couldn't get the plastic pulley off (even with the power steering pulley puller) and had to buy a new one for the new pump. So costed me around 85 all together at oreillys. But it was worth it. And actually it's a rather fast job. All the bolts that you remove line up with the holes in the pulley when you turn it. Good luck!!!
minimika2008 is offline
post #7 of 7 Old 10-11-2012, 04:06 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
The dorman resevoirs are just too hokey looking with some kind of globby glue stuff holding the halves of the tank together. When mine went I bought a cardone rebuilt. The resevoir leaked. So I took it back and bought just the pump and tried to use my old resevoir,it leaked. Thats when I looked at the dormans. I just bit the bullet and got oem. Been worry free every since but that puppy was expensive.
Originally Posted by HighLonesome
coralman is offline
