power steering pump leaking ? - JeepForum.com
post #1 of 12 Old 10-07-2007, 03:27 PM Thread Starter
jeepunlimited
hey guys, well i have a spot on my driveway and i looked underneath, it seemed to be coming from the power steering pump. Its the orignal pump. I cleaned it all off and took it for a 20 minute drive...looked underneath aagain and there are drops of fluid on the bottom of the pump ready to drop onto my driveway.
can anyone tell me if replacement of the power steering pump is a common problem on the 4.0L's ??
also is this a hard job to do guys ?? let me know cause any help would be great. Thanx guys
1993 Jeep Grand Cherokee Limited
Green/Gold, Tan Leather
4.0L , 42RE transmission-- 242 selectable transfer case
Bone Stock with the acception of a K+N drop in filter and my aftermarket stereo, also did alot of new tune up wear and tear parts!
366 000 kilometers and stilll runs great :)
purchased for $125 bucks, amazing daily driver for the money
jeepunlimited is offline
post #2 of 12 Old 10-07-2007, 03:44 PM Thread Starter
jeepunlimited
can anybody help me out?
post #3 of 12 Old 10-07-2007, 04:49 PM
driabyor
driabyor's Avatar
1994 ZJ
I would use a degreaser to clean the spot from the driveway... brake clean would probably be the easiest
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 12 Old 10-07-2007, 04:51 PM
-Joe-
-Joe-'s Avatar
common problem or not things break and leak.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 12 Old 10-07-2007, 05:59 PM
muddyjgc
2005 WK
I'm not sure about it being a common problem, but I had to replace mine at 140k mi.
It wasn't too hard, it would have taken me only about 2 hrs, and that would have included swapping the pulleys and flushing the fluid out of the steering box. But the first pump that I got leaked worse than the original. The second one didn't. Both the original one and the first bad one seemed to be leaking from where the tank connects to the pump. You will need to buy or rent a pulley puller to remove the pulley from the old pump, and the new pump should have a nut and a long bolt to "press" to pulley onto the new pump. On the vehicle you need to loosen and slip the belt off the pump, disconnect the pressure and return lines and remove the 3 bolts that hold the pump to the bracket through the holes in the pulley. Remove the pump and swap the pulleys and the rest is reverse of the removal.
muddyjgc is offline
post #6 of 12 Old 10-07-2007, 06:01 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Try to pinpoint the leak. It could just as easily be the pressure hose.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #7 of 12 Old 07-04-2009, 07:22 AM
ecologito
I am dealing with the same issue, this time I am replacing the pump for the third time. Two of them were bad right off the box from Advance Auto Parts. Their rebuilt stuff is a pain in the Axle. If this one is bad I will go ahead and buy a brand new one from napa.
ecologito is offline
post #8 of 12 Old 07-04-2009, 07:33 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
there's good reason i don't buy many parts from vatozone(advance is the same).
pumps are wear items, they're guaranteed to go bad at some point.
ratmonkey is offline
post #9 of 12 Old 07-04-2009, 10:17 AM
ecologito
I can't find a brand new one locally, I stopped at advance auto and Napa, all they have are the remanufactured ones.
post #10 of 12 Old 07-05-2009, 06:35 AM
kentman
kentman's Avatar
2006 XK Commander
Did mine on the ZJ 4.0L at 216K miles. It died in a blaze of glory. $120 and a few hours later, I was up and running. The hardest part certainly was the pulley swap. I rented the puller. Priming the pump was a pain. It took me a few days to figure out how to do that right. I just needed the pump to spin to get me home 350 miles away. Manual steering works just fine.
'06 XK Limited, 5.7L, QD II, Black, 163K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 126K
kentman is offline
post #11 of 12 Old 07-12-2009, 02:47 AM
ecologito
Finally got the third pump in and now more leaks. I am wondering how long it is going to take for this one to go sour. In the meantime I will consider myself a pump replacer pro. I've got it down to hour and a half from start to finish including replacing hoses and pulley. Let's see ... at 160,000 miles on a 98 cherokee sport, what other things can go wrong? I do not drive off road...
post #12 of 12 Old 07-12-2009, 05:16 AM
Turbonut
On our old ZJ the pump was leaking between the reservoir and pump assembly. Split them and replaced the "O" ring and it was good 'tll it was sold.
Turbonut is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 05:50 AM
New power steering pump and pressure hose, now excessive pump noise Jeeples ZJ Grand Cherokee Forum 14 03-15-2011 03:59 PM
Replaced power steering pump. Leaking. Now what? Crewdude007 ZJ Grand Cherokee Forum 12 11-25-2009 07:23 AM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 10:04 PM
Leaking Power Steering connection on Pump pharriso ZJ Grand Cherokee Forum 17 11-05-2008 01:57 PM
