power steering pump: how to remove old pulley and put on new one? 1997 ZJ V8 5.2 4x4 - JeepForum.com
post #1 of 14 Old 07-05-2013, 08:09 PM Thread Starter
webhostingdesig
power steering pump: how to remove old pulley and put on new one? 1997 ZJ Jeep Grand Cherokee Laredo V8 5.2 4x4
I've read you have to rent some kind of "puller". Does anyone have a picture of this "puller" device so I know I am getting the right thing?
Here is what I am dealing with.
Remove this:
Install this:
webhostingdesig is offline
post #2 of 14 Old 07-05-2013, 08:16 PM Thread Starter
webhostingdesig
Does it look like this?
Question how, then, do I get the new pulley on the drive shaft of the power steering pump?
post #3 of 14 Old 07-05-2013, 08:32 PM Thread Starter
webhostingdesig
This site says " You do not use a "jaw" type puller on these things."
http://www.jeepsunlimited.com/forums...ad.php?t=90808
Anyone have a picture of the right puller? Note that I don't have any threads in the center of my pulley, just a hex/allen type inverse nut, so I don't see a place for anything to screw "into".
post #4 of 14 Old 07-05-2013, 08:45 PM
kachink
You need something like this:
http://www.autozone.com/autozone/acc...fier=2075_0_0_
The kit usually comes with the tools needed to remove and install. There are videos on Youtube showing how to use it.
Jaw type puller isn't strong enough for the press fit. I've done two. One went easy with a similar tool. The other was so tight I bent the 3/8" screw to get it off.
kachink is offline
post #5 of 14 Old 07-05-2013, 08:48 PM Thread Starter
webhostingdesig
Looks like I'm answering my own questions here...
This video shows the correct tool and how to use it to remove the power steering pump pulley.
It looks like this:
post #6 of 14 Old 07-05-2013, 10:12 PM
Will9119
I used this one from Autozone to remove mine. It was a bear to remove. You can rent this tool from any auto parts store and as long as you return it you get your money back.
http://www.autozone.com/autozone/acc...aller/_/N-264z
Will9119 is offline
post #7 of 14 Old 07-05-2013, 10:46 PM Thread Starter
webhostingdesig
I got a "Powerbuilt" kit for $29 + some from Pep Boys, put it on and started to crank it but it's taking a lot of force, almost pulled a muscle in my back turning the wrenches. My power steering pump is not attached to the block. Should I be doing the pulley removal/installation with the pump on or off the block. My hoses are still installed and I don't want to remove them if I don't have to. I'll get started on this again tomorrow some time.
post #8 of 14 Old 07-06-2013, 07:27 AM
Will9119
Take the pump off. It will allow you to get better leverage. Just get some clamps to keeps the hoses from making a mess while you have it off.
Will9119 is offline
post #9 of 14 Old 07-06-2013, 08:46 AM
kachink
x2 - it really takes some torque to get that thing off. I set mine up in a bench vice to do it.
kachink is offline
post #10 of 14 Old 07-06-2013, 09:25 AM
PolkaPower
I used the puller like in the autozone link. I didn't take the pump off. The puller tore the metal lip of the pulley sleeve off and there was no part of it for the puller to grip after that. I ended up cutting it off with a dremmel. The new pulley went on easy.
PolkaPower is offline
post #11 of 14 Old 07-06-2013, 03:05 PM Thread Starter
webhostingdesig
Technically my power steering pump is off, but still attached to the hoses. I don't want to have to mess with bleeding, messy liquids, etc.
I'll just get muscle into it today and spray it with WD40 too.
post #12 of 14 Old 07-06-2013, 08:11 PM Thread Starter
webhostingdesig
I was able to get the broken pulley off with longer armed wrenches and two people. I supported the pump in the engine bay on a 1x1" piece of wood so I wouldn't break anything under the power steering pump.
Problem now is I'm stripping/ed the mounting tool. You can kind of see the first few threads are stripped because the first part of the bolt in the pressure tool is too long to let the threads enter far enough into the shaft to catch properly.
Any tips on mounting this pulley onto the power steering pump drive shaft? Mine is half way on.
post #13 of 14 Old 07-06-2013, 09:26 PM Thread Starter
webhostingdesig
Fixed it was using the wrong bolt. Got the power steering pump on, now the belt wont go on like it did easily before. Now I'm looking for things that can be adjusted because the automatic belt tensioner wont move far enough to let the belt on.
post #14 of 14 Old 07-07-2013, 04:16 PM Thread Starter
webhostingdesig
Originally Posted by WhiteOut View Post
Take the belt off the idler pulley, put it around the tensioner, then put the wrench on the tensioner and loop the belt around the idler.
This worked! Thanks everyone.
