power steering pump failed - JeepForum.com
post #1 of 9 Old 08-20-2013, 10:24 AM Thread Starter
booked101
My power steering pump finally failed. Seems like the bearing for the pulley has broken and wobbling like a mofo. I need help finding out what I need to order to fix it. I dont know whether I need just the pump with or without the reservoir or what? Also there are apparently many different kinds of power steering pumps. Help. Im working on getting a pic up.
good gas mileage is highly overrated.
(J)ust(E)mpty(E)very(P)ocket
booked101 is offline
post #2 of 9 Old 08-20-2013, 10:57 AM
jabba974
Buy the pump with the reservoir...It makes the job alot easier, and its ussaully only a few dollars difference in price....you will also need a pully remover/installer tool to swap the pulleys...most stores should have them for sale, or I know you can rent them from O'reillys or Autozone....Dont forget to replace the o-rings on the pressure hose....
jabba974 is offline
post #3 of 9 Old 08-20-2013, 11:35 AM
sebian
When my gear box finally went out, I also replaced the power steering pump, and took the opportunity to replace the pressure and return hoses. After 15+ years they get a little brittle, and it never hurts to replace them as preventative maintenance.
Watch out for the cheap plastic aftermarket pullies though. I tried to install one, and could never get it seated correctly, so I left my stock pulley on.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #4 of 9 Old 08-20-2013, 01:50 PM
tucsonzj
there was an issue with some of the aftermarket pullies not begin the correct fitment, but not sure if that ever got resolved or what happened. So if you can re use your stock pulley that'd be best. Otherwise, I got my pump off rockauto, no issues as of now. rent a pulley tool or buy one.
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #5 of 9 Old 08-20-2013, 02:10 PM Thread Starter
booked101
Looking at a pump with reservoir at AutoZone. Duralast brand. Going to have my mechanic change it tomorrow morning.
post #6 of 9 Old 08-21-2013, 04:07 PM Thread Starter
booked101
Got the jeep back from the mechanic. Since I picked it up after the shop had closed I didn't get to talk with the mechanic. I have no power steering now. Anything I should check?
post #7 of 9 Old 08-21-2013, 05:33 PM
Uniblurb
Uniblurb's Avatar
Well that's some fine work they did! Check the reservoir to make sure it's full of fluid up to the mark on the dipstick. Also check to see if you can see fluid all over where it sprung a leak or if your belts slipping/loose.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #8 of 9 Old 08-21-2013, 07:00 PM Thread Starter
booked101
Plenty of fluid, no excess fluid other than what came out of the broken pump yesterday, and the belt and pulley are spinning as they should. Any other suggestions?
post #9 of 9 Old 08-21-2013, 08:12 PM
Uniblurb
Uniblurb's Avatar
You may have an air lock in your power steering system somewhere. After installing a new or rebuilt pump the FSM (Factory Service Manual) says you're supposed to jack the front wheels off the ground. Then you turn the steering wheel back and forth 20 time lightly hitting the stops. Don't hold it on a stop turned all the way for more than 2 secs and it should be more like a quick movement turning the other way. Then recheck your power steering fluid level.
Not sure you have the jacks/stands to get both wheels off the ground but this is the procedure to follow. You probably aren't go to be able to do this with the wheels on the ground with no power steering and it might damage something. It probably wouldn't hurt to try turning it just a couple times but if you feel any binding quit. Good luck and let us know how it goes.
Uniblurb is offline
