power steering pump blow - JeepForum.com
post #1 of 3 Old 09-25-2009, 02:54 PM Thread Starter
Tmark
did I totally ruin my power steering pump by tightening the belt to tight??? I had power steering fluid blowing out from the shaft into the pulley and then everywhere. or will it be ok by taking the tension off of the belt....and refilling the reservoir.
Tmark is offline
post #2 of 3 Old 09-25-2009, 03:09 PM
the88thpianoman
2003 WJ
Doesn't your 4.0 have an automatic belt tensioner? Or is that just on the newer ones?
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 3 Old 09-25-2009, 03:19 PM
sandman
just the newer ones. i over tightened mine once and learned my lesson real quick, i ate through a pulley, a water pump and a harmonic balancer. now this is how i do it. tighten it to where i think its a tiny bit too loose, then start your engine and if it squeals tighten it a tiny bit more, and continue the procss untill it stops squealing. my belt still squeaks from time time but im fine with that.
1993 Jeep ZJ. 4.0
sandman is offline
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 05:50 AM
New power steering pump and pressure hose, now excessive pump noise Jeeples ZJ Grand Cherokee Forum 14 03-15-2011 03:59 PM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 10:04 PM
ZJ Power steering pump help Big_Luke ZJ Grand Cherokee Forum 2 10-04-2007 08:34 PM
Power Steering Pump? Skyline ZJ Grand Cherokee Forum 2 12-11-2006 05:43 PM
