Power steering pully? - JeepForum.com
post #1 of 16 Old 08-20-2017, 11:33 PM Thread Starter
Pistolpete926
Has anyone ever have their power steering pully explode on them? Easy fix after replacing upper radiator hose and liquid steeling the holes it put in my radiator? Have just never seen or heard of this? Any explanation of why it would have happens would be nice. Btw I have a small leak in power steering pump on the in hose to the pump. But nothing more then a drip a day maybe, took me months to notice it.
Pistolpete926 is offline
post #2 of 16 Old 08-20-2017, 11:43 PM
kachink
96-98 has a plastic pulley. I had one come apart that was only a few years old. Be very careful when pressing a new one on, I ended up with a hairline crack from trying to hold it from turning while I pressed it on.
You can replace it with a metal pulley from a 93-95, but you need to get the pump mounting bracket from a 93-95 also for it align with other pulleys correctly.
kachink is offline
post #3 of 16 Old 08-21-2017, 12:02 AM Thread Starter
Pistolpete926
It's been Replaced and has been working great im just at a loss as to why it happened. Had me stuck 200 miles plus from home in a small town just big enough to have a o riellys thankfully.
post #4 of 16 Old 08-21-2017, 12:05 AM Thread Starter
Pistolpete926
It only took me 30 min to replace with a manual socket press. But its nice to know you can replace it with a metal one thanks for the info.
post #5 of 16 Old 08-21-2017, 12:25 AM
Timo_90xj
Timo_90xj's Avatar
It's a fairly common issue on the '96+ Jeeps and Dodge trucks for the plastic PS pump pulley to either crack, or even self-destruct to about gazillion pieces.
***Under construction***
Timo_90xj is online now
post #6 of 16 Old 08-21-2017, 01:00 AM Thread Starter
Pistolpete926
yea basically shot gunned my radiator.
post #7 of 16 Old 08-21-2017, 01:27 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, they do that.
I carry a bypass belt, but the steering box is unappreciative.
You can switch to the metal ones from a first gen if you steal the pulley and bracket from a first gen. IMO, I'd rather have the pulley break. When they're 19 years old they break because they've gone brittle, but it takes the pump stalling to do it. The pump shouldn't be stalling.
kg6mov is offline
post #8 of 16 Old 08-21-2017, 05:03 AM
jeepjeepster
Why would you rather have the pulley explode over having a metal pulley?
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #9 of 16 Old 08-21-2017, 05:57 AM
StPaul59
Would this work with a metal pully??
http://m.ebay.com/itm/111616502950?r...&ul_noapp=true
Will a PS bracket like this work with a metal pully from a 95 on a 98? I'd like to fix both issues at the same time.
StPaul59 is offline
post #10 of 16 Old 08-21-2017, 08:58 AM Thread Starter
Pistolpete926
I would rather a metal one but wasnt in a place to shop or piece one together.. had my family with me. I took what was available at the time.
post #11 of 16 Old 08-21-2017, 12:14 PM
kg6mov
Hears the voices
kg6mov's Avatar
Because if the pulley is exploding, something bad has happened to make the pump stall. I'd rather have the pulley explode than the pump destroy itself.
Basically, it's a fuse.
And it doesn't do it if you have a properly working steering system. The pulley blowing up is a symptom, don't treat symptoms, treat the root cause.
kg6mov is offline
post #12 of 16 Old 08-21-2017, 01:58 PM
PolkaPower
Mine crumbled when I touched it while the belt was off but you could visibly see the micro spiderweb cracks in it and it was original so like 17 years old at the time.
They are a composite and become brittle but it takes quite a while.
With the steel pulley you need to add a spacer or washers to line up the grooves.
PolkaPower is online now
post #13 of 16 Old 08-21-2017, 02:23 PM Thread Starter
Pistolpete926
Would a slow like really slow leak cause it to stall?
post #14 of 16 Old 08-21-2017, 02:25 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yeah, if you're low on fluid the pump is working overtime. It'll fry the pump slowly.
kg6mov is offline
post #15 of 16 Old 08-21-2017, 03:07 PM
PolkaPower
Is it noisy? They usually complain pretty loud if it's low on fluid.
