Power Steering Moan - JeepForum.com
post #1 of 15 Old 09-24-2009, 12:47 PM Thread Starter
joecalik
2003 WJ
Power Steering Moan
I have a 2003 WJ Limited.. When i turn the wheel it makes a moaning sound! Has anyone experienced this before? How do i resolve this problem? I've been dealing with it for a while now, its starting to annoy me.. I appreciate any help...
joecalik is offline
post #2 of 15 Old 09-24-2009, 01:27 PM
befumo
Same problem. Wondering if mine is the serpentine belt because i squeak sometimes when i come to a stop. Always when i take tight turns though.
'89 YJ Wrangler - Sold
'95 ZJ Orvis Edition
'89 YJ Islander
befumo is offline
post #3 of 15 Old 09-24-2009, 01:34 PM
LordHobbit
Is your jeep in love with you?
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #4 of 15 Old 09-24-2009, 01:35 PM
the88thpianoman
2003 WJ
I had the same symptom; it's been silent since installing a new power steering pump.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #5 of 15 Old 09-24-2009, 01:46 PM
froggo27
froggo27's Avatar
First i'd check if you have power steering fluid. My was doing the same thing for about a year till my pump gave out and i had to get a new one installed.
Kamil
04 WJ Limited
froggo27 is offline
post #6 of 15 Old 09-24-2009, 01:53 PM
befumo
Yeah mine was low. Why i think its the pump, previous owner didnt know you had to keep up on fluids.
Unfortunately the pumps are expensive.
'89 YJ Islander
befumo is offline
post #7 of 15 Old 09-24-2009, 04:24 PM
sandman
mine moaned so i siphoned all the fluid out of it and added RP power steering fluid and it has been silent since and that was like a year ago.
1993 Jeep ZJ. 4.0
sandman is offline
post #8 of 15 Old 09-24-2009, 04:49 PM
silver_laredoSE
thats just its way of saying harder....harder...
--Steve--
~RIP Tory Edwards "bigbluezj94"~
Silver Jeep Club Member #4
2008 JK
Black Diamond 3in
315/75R16 KM2s
XRC8
Smittybuilt XRC Stinger
Flat fenders
OLD WJ BUILD THREAD:
silver_laredoSE is offline
post #9 of 15 Old 09-24-2009, 05:00 PM
Subie-Jeep
2014 MK Patriot
it will moan if its low on fluid,make sure its topped off.
2014 Patriot Latitude
2006 GMC Sierra 1500,reg.cab, short box,4x4,mostly stockTraded in
1994 ZJ 2" BB,31" TrXus MT-sold and have regretted it ever since :(
2002 Subaru Impreza 2.5RS w/ too much to list here
1994 Toyota 4Runner-I couldn't destroy it but the rust was making good progress-Traded in.
Subie-Jeep is offline
post #10 of 15 Old 09-24-2009, 09:19 PM
DigitalVex
Power steering hoses, if touching, will moan as well. Make sure the hoses are not in contact with each other. Sometimes you have to shift them around a little in the engine bay. (Pro tip - Keep them away from pulley's and fan blades)
2013 JK Rubicon 2.5" Metalcloak Elite lift, JCR Defender front, JCR Vanguard rear, AEV wheels
DigitalVex is offline
post #11 of 15 Old 09-25-2009, 07:57 AM
nick62087
i changed my fluid and my moan pretty much went away. I sucked out the reservoir with a turkey baster, refilled, started engine, turned wheel a few times, shut off, and repeated about 5 times.
Someone put ATF in there, it was a nasty color and it made a horrible whine. I replaced the fluid with Prestone power steering fluid, says it supposed to stop squeals (red bottle, got it at walmart)
Probably not the most efficient way to change fluid, but it was easy, and i wasn't worried about introducing air into the system, since i was only emptying and refilling the reservoir.
nick62087 is offline
post #12 of 15 Old 09-25-2009, 08:11 AM
squashman702
1994 ZJ
ATF shouldn't have mattered.
The pumps are $65 plus $40 or so core charge at Advanced. It comes without the pulley (another $20).
It cost me $15 to get the pulley pressed on (do NOT install it using a hammer) and about 45 minutes to remove and replace on my 5.9. This job was made a little easier with the efan, and because the tensioner on the 5.2/5.9 is much easier to work with than on my 1998 4.0.
Definitely not a job I would pay to have someone to do if you have basic mechanical ability.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #13 of 15 Old 09-25-2009, 08:23 AM
WiCkeDuDe
The WJ pumps are more money and they are a common problem. They are NOT to be filled with ATF. Wjjeep.com states you must even use the mopar fluid. Mine whined after using the mopar fluid so I changed to the RP fluid and it stopped whining now. I know the pump is somewhat hurt but it seems to be quiet now to where I dont hear it with the hood closed. They all revised the resevior for the pump on the factory pump but its very expensive for the pump assembly. Upwards of $600. You can check around for a JY pump but the chances of it whining too are probually good.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #14 of 15 Old 09-25-2009, 11:04 AM
LordHobbit
Priceless.
post #15 of 15 Old 09-25-2009, 01:04 PM
volvite
Lucas powersteering fluid or the conditioner would help. Mine made a few noises until i put some lucas in it, and it shut up.
volvite is offline
Replaced power steering box. Now steering power comes and goes. bjl95mustang ZJ Grand Cherokee Forum 2 01-02-2010 06:41 PM
ZJ power steering intermittant power loss Coblue ZJ Grand Cherokee Forum 2 12-06-2008 11:49 AM
99 WJ w/ QD moan & groan from transfer case? LEDFoot ZJ Grand Cherokee Forum 8 11-02-2005 12:50 PM
A rattle, a moan, and a little rythmn. Texas96 ZJ Grand Cherokee Forum 3 09-06-2002 04:21 PM
Losing power steering and power brakes bsheft ZJ Grand Cherokee Forum 2 01-05-2002 04:05 PM
