Power Steering...just bought jeep need help - Page 2 - JeepForum.com
post #16 of 28 Old 06-08-2013, 09:45 PM
Virmagicus
Virmagicus's Avatar
Originally Posted by Jwilley90 View Post
It has 250k on it. the engine has been rebuilt with 70k on rebuilt engine it is running stock tires right now. Here are 2 pics of my actual jeep where its leaking and the gap.....it just pours from that gap.
The gap in between the top of the arm and the box is fine. Just replace the seal on the bottom if the box checks out. The nut on the pitman arm is torqued to about 190ft lbs.
Jeff
Virmagicus is offline
post #17 of 28 Old 06-08-2013, 09:46 PM Thread Starter
Jwilley90
I just want to fix it the easiest and cheapest way lol.
Jwilley90 is offline
post #18 of 28 Old 06-08-2013, 09:47 PM
Virmagicus
Virmagicus's Avatar
Have someone turn the wheel back and forth and see if the shaft that comes out of the box (where the pitman arm is) is solid and does not have play... if it does just replace the whole unit.
Jeff
post #19 of 28 Old 06-08-2013, 09:53 PM Thread Starter
Jwilley90
Okay i will do that and check it out. If it does look solid I will just use a seal kit, and i can replace the seal without removing the steering box? Or how do i install the seal. Is there a link somewhere on here?
post #20 of 28 Old 06-08-2013, 09:57 PM
Virmagicus
Virmagicus's Avatar
Jeff
post #21 of 28 Old 06-08-2013, 10:01 PM Thread Starter
Jwilley90
I thought i could do it without having to remove the box.
post #22 of 28 Old 06-08-2013, 10:02 PM
Virmagicus
Virmagicus's Avatar
I added a vid...
Jeff
post #23 of 28 Old 06-08-2013, 10:09 PM
JasonStebbins
I like that guy.
Poop
JasonStebbins is offline
post #24 of 28 Old 06-08-2013, 10:22 PM Thread Starter
Jwilley90
Thank yall so much. This will be my early morning project. Thanks again.
post #25 of 28 Old 06-08-2013, 10:31 PM
Virmagicus
Virmagicus's Avatar
Originally Posted by JasonStebbins View Post
I like that guy.
haha
Jeff
post #26 of 28 Old 06-17-2013, 09:41 AM
jepauto
Why the durango box?
What are the +'s?
jepauto is offline
post #27 of 28 Old 06-17-2013, 04:47 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I just want a battle axe like virmagicus except michelob light. Dude lives in gulf breeze, so he's working in 100 percent humidity with a heat index above 95. I feel his pain,lol.
Originally Posted by HighLonesome
coralman is offline
post #28 of 28 Old 09-12-2013, 09:29 AM
picflight
Curious to know what you ended up doing, replace steering box or changed seals?
I have the exact same issue with mine, PS drains in 20 min.
picflight is offline
