-   -   Power Steering...just bought jeep need help (http://www.jeepforum.com/forum/f13/power-steering-just-bought-jeep-need-help-1534023/)
Jwilley90 06-08-2013 08:31 PM
Hey guys I bought a 98 jeep grand cherokee yesterday with the power steering not working. The guy put a power steering pump in it but there is absolutely 0 power steering. i got to fight it to turn the wheel lol. I fill it up with power steering fluid and as soon as i turn on my jeep and attempt to turn the wheel it all is leaked out and gone. So i do not know what to do.
Glad to be apart of the jeep forum now.
JasonStebbins 06-08-2013 08:38 PM
Welcome to the forum. :2thumbsup:
Have somebody else turn the wheel while you pinpoint the leak. If it's been running dry the pump is probably toast. Fix the leaking pump/hose/line and see if it works. Otherwise you're probably looking at a new pump.
jm8881 06-08-2013 08:38 PM
I think the obvious question is where is it leaking from?
Jwilley90 06-08-2013 08:47 PM
I have no idea where the leak was. I got under the jeep and i just saw a couple of drips coming off the sway bar. Ill have someone else turn the wheel and maybe i can pinpoint the leak.
JasonStebbins 06-08-2013 08:53 PM
If he replaced the pump already it's most likely the lines. There's a rubber one and a steel one. Wipe everything down and have someone turn while you watch with a light.
It could also be the steering box leaking. Make sure everything is clean and find where it's coming from.
Jwilley90 06-08-2013 09:01 PM
Pinpointed the leak. As soon as the engine starts it all drips out fast on the underside of the steering box...where that little arm comes down to the sway bar. I can take a picture of exactly where it leaks if need be.
Jwilley90 06-08-2013 09:05 PM
1 Attachment(s)
Pic of where leak is.......i just found this pic off google but right there is where it steadily leaks out quick.
JasonStebbins 06-08-2013 09:06 PM
I think you're talking about the pitman arm that attaches to the track bar?
So it's the steering box and not the steering pump or a line? That's not fun to replace so make sure it's that.
Jwilley90 06-08-2013 09:07 PM
Yes exactly. FFFF so i will have to replace the steering box?
JasonStebbins 06-08-2013 09:10 PM
From the looks of it, yes. I've never seen one piss out all the fluid that fast so it must be a pretty bad seal.
Might as well upgrade to the Durango steering box. :thumbsup:
JasonStebbins 06-08-2013 09:13 PM
If you're positive it's leaking at the pitman arm nut, there is a seal kit you can buy from the dealership for around $35.00 and it's not that hard to install.
Jwilley90 06-08-2013 09:21 PM
Yeah im positive it is leaking from right there...but on my jeep there is kinda big gap from the arm to the steering box would that matter? Is it easier to replace the whole box or the sealing kit? Thanks alot for helpin me.
JasonStebbins 06-08-2013 09:26 PM
A picture says a thousand words. :rofl:
How many miles on the box? Running stock size tires? If it's just a bad seal I wouldn't replace the whole box. You don't even have to remove it to install the new seal. The gap you're talking about is strange. Maybe the ball joint end of the track bar is bad or the 32mm nut is actually loose?
Jwilley90 06-08-2013 09:36 PM
2 Attachment(s)
It has 250k on it. the engine has been rebuilt with 70k on rebuilt engine it is running stock tires right now. Here are 2 pics of my actual jeep where its leaking and the gap.....it just pours from that gap.
JasonStebbins 06-08-2013 09:39 PM
Looks like it's just the seal. It's up to you whether or not you want to replace the box.
If it was mine with 250,000 miles I would just opt for the Durango box upgrade. Especially since the motor has been replaced. Who knows how the other seals and internal parts are.
Your choice though!
The time now is 10:19 AM.
