Power Steering Hose on 4.7 - JeepForum.com
post #1 of 8 Old 12-27-2008, 03:29 PM Thread Starter
boundsmb
2005 WK
2001 GC LTD. Bought hose (HP) 5019708AD from dealer. The bends were way different than original. They said it needed to be forced to fit. The dimensions were off by 2" at motor and had a 45 degree at pump where a 90 degree bend was needed. Any ideas?
boundsmb is offline
post #2 of 8 Old 12-27-2008, 03:44 PM
WA_WJ
2003 WJ
When i replaced mine the new one was different but the dealer said it would be so i just made it fit.
2003 Overland 31" KM 2's
WA_WJ is offline
post #3 of 8 Old 12-27-2008, 04:47 PM
RRAM
not sure what you paid for that hose, but I had one go on my jeep and one on my sons neon. I took them to the farm supply and they braze threaded ends on the pipe and replaced the hose for 40 bucks. If I ever have a problem again I just replace the hose. Not likely to ever happen again now.
Reg
93 ZJ 5.2 auto
2" bds lift and shocks, 31" tires
04 GC Limited 4.7 Wife drives this one
RRAM is offline
post #4 of 8 Old 12-27-2008, 05:16 PM
mtcox
When I bought mine from the dealer (and they're only available from the dealer) the parts man asked for the VIN. He said the hoses could be different based on when the engine was manufactured. The hose he sold me was an exact fit. No issues, no bending, no problems. The only tight spot was the fitting to the pump itself. It's a little tight but a little patience and an assortment of wrenches will work. I've heard that cutting a box wrench will assist even more with the installation of that top thread.
2001 Jeep Grand Cherokee Limited 4.7L
mtcox is offline
post #5 of 8 Old 12-27-2008, 09:28 PM Thread Starter
boundsmb
2005 WK
Do you have the part number of the one you bought?
boundsmb is offline
post #6 of 8 Old 12-28-2008, 05:10 AM
Turbonut
As that is the correct part number, stupid question, but are you installing it in the correct direction? If it's the 2 piece assembly it's the correct part. The PS end has the nut attached, but the fan motor assembly is 2 pieces. The sleeve is installed slightly into the fan motor, the the metal "tube" is then inserted, then tighten all down.
Did a Google:
http://cgi.ebay.com/ebaymotors/2001-04-Grand-Cherokee-power-steering-hose-5019708AD_W0QQitemZ190265841059QQcmdZViewItemQQims xZ20081110?IMSfp=TL0811101110007r26411
Turbonut is offline
post #7 of 8 Old 01-05-2009, 09:56 AM Thread Starter
boundsmb
2005 WK
Went back to dealer. Got hose again. It was about 10 minute install. Hardest part was starting thread on pump. It probably took 8 of the ten minutes to hit correct angle for fitting to start. Not a very good redesign.
boundsmb is offline
post #8 of 8 Old 01-06-2009, 03:41 AM
FreemasonJeeper
FreemasonJeeper's Avatar
The redesign sucks. I had to use a dremel and a cutting disk to cut off the chunk of metal in front of the threads to that I could get the threads to reach the pump. Worked great after I did that.
FreemasonJeeper is offline
Power Steering Pressure Hose 94 GC 4x4_billy ZJ Grand Cherokee Forum 5 01-25-2010 12:25 PM
Power Steering Hose help- TJTony ZJ Grand Cherokee Forum 7 06-08-2009 10:29 AM
Power Steering Hose thegoat78 ZJ Grand Cherokee Forum 4 01-24-2009 03:57 PM
4.7L power steering to fan controller hose ?? saki669 ZJ Grand Cherokee Forum 8 09-01-2007 08:05 AM
Power Steering Hose Double E ZJ Grand Cherokee Forum 2 06-30-2004 03:45 PM
