2003 jeep grand cherokee limited, engine code N
I have a pretty bad leak in the p/s pump. i replaced the pump only to find that it is the 1/2" high pressure line that runs from the pump to the fan clutch. It is the quick connect fitting (right where the line connects to the pump) that leaks. Is this line a dealer item? anyone know any quick fixes? Im not sure (conceptually) how this fitting can be leaking. What im guessing is that there is a flare inside the connect nut that leaks. i replaced the o-ring, but of course, it still leaks. HELP!?
Joe
Joe
