Power Steering - JeepForum.com
post #1 of 11 Old 04-02-2006, 11:48 AM Thread Starter
Mrtwister29
Power Steering
Hey so the other day the power steering pump in my jeep broke so i went out and bought a new one and put it on. before i put it on i drained all the old fluid out of the system. so i got the pump on and filled the tank , turned the wheel so it would fill the system. so after the bleeding i lowered my jeep and started it up. the power steering worked for like 10 secinds then stopped. the werid thing is if i wait like 30 seconds without turning the wheel the power steering will be easy again for 10 more seconds then go back to hard. also i took it for a test drive just to see how hard it was when actually driving and the power steering seemed to only work when i was pressing the gas. if you know anything about how to fix this please let me know, i really need my car to get work cause right now im on my bike. thanks
Mrtwister29 is offline
post #2 of 11 Old 04-02-2006, 01:49 PM
AgitatedPancake
try re bleeding it, kinda sounds like you have ALOT of air in the system. Bleed it per what the manual/instructions say its the only way to do it.
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #3 of 11 Old 04-02-2006, 01:58 PM Thread Starter
Mrtwister29
i have already rebleed it once and still the same thing. do i need to keep on turning the wheel? for alot longer? cause i have done it for about 10 mins straight and kept filling the tank to make sure it is full. so should i keep on turning the wheel to pump it some more and for how long?
post #4 of 11 Old 04-02-2006, 02:02 PM
jeep946
jeep946's Avatar
does the power steering res keep going down after you bleed or does it stay the same.
jeep946 is offline
post #5 of 11 Old 04-02-2006, 02:04 PM Thread Starter
Mrtwister29
for like the first 5 mins it went down with air bubbles coming up and i would fill it again and then it stopped having air bubbles come up so i figured it was done bleeding
post #6 of 11 Old 04-02-2006, 02:12 PM Thread Starter
Mrtwister29
also i took off the pump and made sure nothing was blocking the flow of it cause it works when i step on the gas. is there maybe a way to increase the flow of it at idle? it seems like power steering kicks in around 3000 rpms
post #7 of 11 Old 04-02-2006, 02:32 PM Thread Starter
Mrtwister29
one more thing does the Speed Proportional valve have anything to do with the flow of the fluid? and how much is released into the power steering system?
post #8 of 11 Old 04-02-2006, 05:08 PM
zjhitman
If I remember correctly, the speed proportional steering is supposed to give you more power assist when maneuvering at slow speeds and less at highway speeds. Sounds like there is still a lot of air in the system. Get both front wheels off the ground and then unlock the steering wheel and turn the wheels 10 times to the left and 10 times to the right with the ENGINE OFF. Not hard to do at all with the weight off the wheels. Then let is sit for about half an hour, check the fluid and fill to proper level and go for a drive. That should fix it.
zjhitman
zjhitman is offline
post #9 of 11 Old 04-02-2006, 07:30 PM Thread Starter
Mrtwister29
so ive done all that about 3 times now and still seem to have the same problem which is the power steering will work for like 10 seconds then stop. i cant see any more bubbles coming up in the tank so im pretty sure all the air is gone.
post #10 of 11 Old 04-02-2006, 08:02 PM
Airborne Lee
Airborne Lee's Avatar
It sounds like there is a blockage in the connection from the res to the pump? Also, check the other hoses going to the steering box and fan. (if applicable).
'16 JKU Rubicon, Tan, RR Front Bumper, 9500i, Atlas Rear w/Tire Carrier M416 Trailer
Airborne Lee is offline
post #11 of 11 Old 04-02-2006, 09:28 PM Thread Starter
Mrtwister29
so im pretty sure there is no blockage in any of the lines.
Replaced power steering box. Now steering power comes and goes. bjl95mustang ZJ Grand Cherokee Forum 2 01-02-2010 06:41 PM
How do you know if your power steering pump is speed portional steering? sweetie ZJ Grand Cherokee Forum 9 06-27-2009 10:04 PM
ZJ power steering intermittant power loss Coblue ZJ Grand Cherokee Forum 2 12-06-2008 11:49 AM
difficulty steering/loss of power steering??? bsteele WK Grand Cherokee & XK Commander Forum 0 07-23-2007 10:46 PM
Losing power steering and power brakes bsheft ZJ Grand Cherokee Forum 2 01-05-2002 04:05 PM
