Power seats... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Power seats...
Light up the holidays with LED lights from JeepHutIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!
Unread 12-05-2014, 05:25 PM   #1
Caish
1987 XJ Cherokee
Power seats...
My 97 ZJ, I have a seat issue.
The motor is working you can feel the seat try to move, but only the left track,
the right one appears stuck.
Anyone actually took it apart and unjammed a track?
Is it common to have a track jam up?
Thanks for any advice you can give.
Join us on Jeeperz Creeperz on Google+
Caish is offline   Reply With Quote Quick reply to this message
Unread 12-05-2014, 08:23 PM   #2
fishermandave95
I would cheek make sure u dint have something Jamed in it . Coin. French fry . Something like that maby ? Try some spray lube see if that might help
fishermandave95 is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 03:04 AM   #3
1998_ZJltd
disconnect the battery ..
remove the floor mats ..
do under the seat .. two bolts in the back and two in the front ..
you may need to be creative to get the bolts out without moving the seat ...
I used an open end wrench and it took forever ...
disconnect the power plug ..
remove seat and flip it upside down ...
you can the grease and clean all the crap the previous owners spilled down the seats ...
I had a lot of stuff in the tracks ...
a little marvel oil and cleaning was what it took w mine ..
installation reverse ......
I cleaned the carpet when I had it out and did the passenger side just for maintenance
1998_ZJltd is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 08:12 AM   #4
xcaliber81
1994 ZJ
I had all kinds of fun getting those bolts out and I had to do it twice.
xcaliber81 is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 08:39 AM   #5
misfit77
My driver power seat did not want to recline. So spent time and money getting used manual seats. In the process of removing seat covers I had to diassemble the moving parts.
Sure enough after putting the power seat back together with different covers, it worked.
FML. It was a lot of work.
misfit77 is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 04:09 PM   #6
superj
1987 YJ Wrangler
We juat switched straight to manual seats. They are lighter and sit lower so your not rubbing the head liner with your hat
Slow ride, take it easy
superj is offline   Reply With Quote Quick reply to this message
Unread 12-06-2014, 04:23 PM   #7
xcaliber81
1994 ZJ
What kind of hat are you wearing lol. I can sit with my hard hat on with the front sitting a bit higher.
Unread 12-06-2014, 04:42 PM   #8
Caish
1987 XJ Cherokee
Well I messed with it today and oiled it and the tracks, I think the track is stripped out.
I do not wantt o change the seat if I can help it.
might pull them out and see if a set of XJ manual tracks will bolt to the seat.
Unread 12-06-2014, 05:21 PM   #9
xcaliber81
1994 ZJ
I have some manual tracks but the drivers side needs coaxing to move lol.
Unread 12-07-2014, 06:07 AM   #10
coralman
I can wish can't I?
coralman's Avatar
I still have a set of power seats I'm installing one day, and a spare set of tracks to boot. You can never have enough spares with a ZJ, if I had a warehouse to put the stuff I'd make a living pulling parts and selling them. That is until all the zj's were gone and then I would start on wj's
Links to axle rebuilds, mount replace,a/c box rebuild,ect in history section of my profile page
coralman is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 07:07 AM   #11
ZeeJay1997
if you've never taken the seat bolts out before be sure to get under the vehicle and hit the bolts with some PB Blaster and wire brush. If the bolts seize in the threads, you're in for some cussing and busted knuckles.
ZeeJay1997 is offline   Reply With Quote Quick reply to this message
Unread 12-07-2014, 07:32 AM   #12
superj
1987 YJ Wrangler
We had normal old power leather seats from the limited but every time I drove it, the little dot on top of the hat would rub the head liner. The seats moved all directions fine but my hat rubbed the top.
I have to have a hat anytime I go outside (skin cancer sucks) and normally take it off while driving but I get in and then take it off so I would get in and hit the top then take the hat off. It got old hitting that dot. I sat the manual seats next the power seats to compare the heights and the power seat tracks are a lot taller then the manual ones.
Unread 12-07-2014, 10:54 AM   #13
xcaliber81
1994 ZJ
Yea the power seats do sit higher i have also compared.
Unread 12-07-2014, 06:49 PM   #14
superj
1987 YJ Wrangler
No cowboy hats, ha ha ha. Regular ol' ball caps
