power seat wire and blowing 30amp fuse - JeepForum.com
post #1 of 4 Old 09-14-2012, 09:35 PM Thread Starter
tylersjeep
1994 ZJ
Dose anyone know how to fix a power seat short I keep replacing to fuse and it keeps blowing and before it it dose I get lots of smoke, it seems its no longer grounded how on earth do I fix this? I need Pictures not a wiring diagram
tylersjeep is offline
post #2 of 4 Old 09-15-2012, 12:27 AM
MarsZJ
I can snap some pictures tomorrow if you like but you remove the side panel trim from the seat where the controls are i think its 3 long screws. Then take a look at the wires for signs of melted plastic and crossed wires.
i had this same thing going on, i had to take the controls off the side of the seat and i found burnt and arcing wires, it seems as if over time the wires to the switch get worn away by sitting in the seat. I re-did all the wiring in that seat and it was cured. Very easy fix, good luck.
MarsZJ is offline
post #3 of 4 Old 09-15-2012, 05:46 PM Thread Starter
tylersjeep
1994 ZJ
please post some pic thanks
post #4 of 4 Old 09-16-2012, 05:59 AM
Foundrydude
Nobody can show you a picture of your short, because there's many reasons it could be shorting out.
The seat is bolted to the floor with 4 bolts, some may have plastic covers that are held on with a phillips head screw. You need to unbolt the seat, flip it over, and have a good look.
The source of the smoke may not be the cause of the short. Look for wires that are pinched or kinked. You might have a bad motor or a bad switch. It's gonna take some common sense and investigation.
BTW, if it was no longer grounded, it just wouldn't work. DC electricity is a loop that uses your car body to loop back to the battery. Open the loop (no ground), and you get no flow anywhere on the loop.
good luck
Foundrydude is offline
98 Power distribution center fuse keeps blowing, please help. bcollier1823 ZJ Grand Cherokee Forum 20 07-26-2017 03:41 PM
20A fuse in power distribution box constantly blowing am9010 ZJ Grand Cherokee Forum 9 12-01-2015 06:02 PM
Help! Blowing the ECM fuse..... sludge06 ZJ Grand Cherokee Forum 4 08-08-2011 10:23 AM
Blowing fuse 97jeepgcl ZJ Grand Cherokee Forum 5 12-20-2009 05:29 PM
Fuse #3, 10AMP for Power Mirrors is blowing sbcjeep WK Grand Cherokee & XK Commander Forum 4 01-03-2009 09:40 AM
