Power question's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Power question's
NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDWe have Engo 10k Synthetic IN STOCK!!! Hurry while supplieSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 11-22-2013, 06:55 PM   #1
OregonZJ98
1991 XJ Cherokee
Power question's
What is a cheap way to increase my power in my jeep and how much would it cost?
OregonZJ98 is offline   Reply With Quote Quick reply to this message
Unread 11-22-2013, 07:47 PM   #2
newfieZJ
Replace the down pipe off the pass side manifold . Said to be worth 10 ponies . Cost unknown , check local muffler shop
Replace cat and muffler to open the 2.25 pipe diameter to 2.5" . Use high flow products and it might net another 10-20 . $200 ish if you can DIY . If you plan on major hp mods , open the exhaust to 3" , depends on future plans .
Replace tail pipe if other mods are done , it's crimped also .
Exhaust is your starting point to increase what you have , if you need more , you can move forward after that's done . Nothing cheap in the world of increasing hp
newfieZJ is offline   Reply With Quote Quick reply to this message
Unread 11-22-2013, 08:55 PM   #3
PolkaPower
SCT tuner with a tune from Flyin' Ryan'. If you are stock it will cost around 300ish for the hand help and I don't know about the programming. You would have to email him and ask. There is no cheap way.
http://www.dakotart.com/forum/showthread.php?t=28073
http://thespeedfreaks.net/showthread...0190-FlyinRyan
PolkaPower is offline   Reply With Quote Quick reply to this message
Unread 11-23-2013, 03:03 AM   #4
Exdecuk
NO2 has to be the cheapest bang for the buck if you only want it in short bursts. These Jeeps need plenty of $$$ thrown at them to get em moving, they are HEAVY SOBs
A man will pay $2 for a $1 item he needs.
A woman will pay $1 for a $2 item that she doesn't need but it's on sale.
Exdecuk is offline   Reply With Quote Quick reply to this message
Unread 11-23-2013, 05:28 AM   #5
coralman
I can wish can't I?
coralman's Avatar
Buy the disc " sounds of nascar" and a set of earbuds.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is offline   Reply With Quote Quick reply to this message
Unread 11-23-2013, 05:53 AM   #6
kensnelling
What kind of power are you referring to? Low RPM torque or high RPM horsepower? Most of us spend more time in the lower RPM range than the upper RPM range.
Ken
kensnelling is offline   Reply With Quote Quick reply to this message
