Power Locks/Power Windows on Passenger Side - JeepForum.com
post #1 of 3 Old 07-08-2005, 09:51 AM Thread Starter
ccox
Sorry if I'm rehashing things that have already been discussed but I'm still not 100% sure what my problem is.
Yesterday I noticed that the power windows on the passenger side did not work but the ones on the driver's side did. At the same time the power door locks quit working all together. None of the doors will lock or unlock. Then it all started working again but by the time I got home from work I had the same problem.
After reading the archives I figured it might be the wires in the door. I did a quick inspection of both doors and it didn't look like I had any broken wires. Since none of the doors will lock or unlock based on stuff I read in the archives I assume that it's not the door modules unless both of them went out at the same time. I also assume it is not the actuators for the same reason.
When I push the lock/unlock button I can hear some clicking in the doors like it is trying to work.
I wouldn't think it was a fuse since the passenger windows and the door locks are going out at the same time. Unless they are on the same fuse for some reason.
Should I investigate the door wiring further? Is there something else that I should also look into?
Thanks for any help you all might give me.
ccox is offline
post #2 of 3 Old 07-08-2005, 09:59 AM
CaliforniaJeep
CaliforniaJeep's Avatar
I had a similiar problem on my ZJ with my passenger door's lock/window working when it wanted to. I checked the rubber boot between the door and the body where all the wires were and every thing looked fine so I took the door panal off and found that the connector that connects to the switch was loose. I popped it back into place and secured it with electrical tape and it works fine now.
Hope that helps!
-Johnny-
~Updating~
CaliforniaJeep is offline
post #3 of 3 Old 07-09-2005, 09:46 AM Thread Starter
ccox
Californiajeep,
Was it just your passenger door lock that was not working or was it all the door locks? In my jeep, none of the door locks work and the passenger side windows don't work.
Mine is a 96 GC Laredo. I forgot to mention that before.
ccox is offline
Power Windows and Locks 06ltd WK Grand Cherokee & XK Commander Forum 1 01-08-2010 03:32 PM
Power Locks and Windows donstylez ZJ Grand Cherokee Forum 0 10-27-2009 04:27 PM
PASSENGER SIDE windows/locks/mirror inoperative pineacre ZJ Grand Cherokee Forum 1 01-07-2009 05:04 PM
Passenger power door locks chrisstromberg ZJ Grand Cherokee Forum 1 11-02-2007 05:39 PM
Power Door Locks/Windows CaptainOats ZJ Grand Cherokee Forum 10 06-06-2006 06:00 PM
