power locks dont work - JeepForum.com
post #1 of 6 Old 02-12-2013, 09:04 AM Thread Starter
93zjgrand
My power locks dont work, when i hit the switch i can hear what i think is a relay inside the dash, but no lock, none of the doors work
93zjgrand is offline
post #2 of 6 Old 02-12-2013, 12:07 PM
Scopez
1994 ZJ
You hear any of the motors in the door trying to work? If so, then you need door actuators. The master switch could have went bad. When I had my back door panels off, the locks/windows would not work until I plugged the switch back up.
I see your name says 93, my 96/97 could be a tad different?
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #3 of 6 Old 02-13-2013, 09:06 PM
KoreaZJ
1994 ZJ
If you hear relay clicking for both LOCK/UNLOCK, but neither work, then check Fuse#14 (20 amp) in Fuse Block located at passenger end of dash.
If doors UNLOCK, but fail to LOCK (and no LOCK relay clicking), then Chime Module could be bad/missing. Does your seatbelt warning chime work?
Chime module is located under drivers side dash...
Relays are in Relay Center located below removable panel in bottom of glove box...
KoreaZJ is offline
post #4 of 6 Old 07-03-2013, 11:45 PM Thread Starter
93zjgrand
ok. i dont have a set blet chime modulae but it does chime with the lights on and jeep not running... you can only hear the relay for lock not unlock, but neither work.... what else could it be, and the fuse is good on passanger dash
post #5 of 6 Old 07-04-2013, 02:07 AM
AVR2
There are a bunch of electrical tests you can do. You really need to read section 8P of the FSM. I've sent you a private message.
AVR2 is offline
post #6 of 6 Old 07-04-2013, 09:25 AM
Kingr98
Did your locks work at any point or were they broke when you got it? Did they all stop working at the same time?
Kingr98 is offline
