power lock problem - JeepForum.com
post #1 of 11 Old 06-30-2006, 05:50 PM Thread Starter
97_Jeep
power lock problem
Hi Everybody,
My girlfriends 97 grand cherokee's drivers side door wont lock or unlock with the switch or remote, it'll lock/unlock manually so I took the door panel off driver and passenger side to compare and I lubed up everything in the drivers side. It seems when you hit the switch you can hear the motor make a really faint noise but it wont throw the actuator rods(compared to passenger side where it immediately throws the lock open/closed), everthing is connected and running smooth so I think the motor has crapped out. any thoughts?
Have any of you changed theses motors before? Very difficult? Any Tips?
thanks.
97_Jeep is offline
post #2 of 11 Old 07-02-2006, 08:03 AM Thread Starter
97_Jeep
nobodys changed one of these?
97_Jeep is offline
post #3 of 11 Old 07-02-2006, 08:07 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sunday mornings on JF are pretty slow.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 11 Old 07-02-2006, 08:08 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
They are pretty easy to change. Just keep the panel off and get to it.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #5 of 11 Old 07-02-2006, 09:37 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Very easy to change out. I'm on my third one that's done what you're seeing. The motor lets out a little fart, but doesn't move the arm. Pull the door panel, peel back the vapor barrier, reach back in there and flip up the little jesus clips holding the rods in place, remove the torx head bolts from the edge of the door. Installation is reverse of removal.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 11 Old 07-02-2006, 10:29 AM Thread Starter
97_Jeep
Thanks for the info guys, figured it woldnt be that involved.
97_Jeep is offline
post #7 of 11 Old 07-02-2006, 11:12 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Definitely not bad at all. Hopefully you don't have the crappy luck that I have. Pretty much resigned myself to finding another way to make the power locks work
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #8 of 11 Old 07-02-2006, 11:35 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
You could hire some midgets but, I'm sure there is some law against that.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #9 of 11 Old 07-02-2006, 12:09 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Some of those midgets eat a lot! I can barely afford to keep my kid fed!
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #10 of 11 Old 07-05-2006, 11:18 AM
Falcor
Falcor's Avatar
My wife's Jeep is doing the same thing. What is the best place to get a replacement?
2005 Unlimited
(sold) 07 JK Rubicon Unlimited, 97 ZJ Laredo - 4.0L, 98 TJ Sahara, 78 CJ-7, 88 Grand Wagoneer
Falcor is offline
post #11 of 11 Old 07-05-2006, 11:30 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Dealership or boneyard. Not available at Autozone/Checker/Etc as far as I know.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
Grand Cherokee power window/lock problem 737FlyGuy ZJ Grand Cherokee Forum 69 01-04-2017 04:54 PM
1996 Grand Cherokee power window and lock problem jrenegade13 ZJ Grand Cherokee Forum 2 12-31-2011 09:36 AM
94 grand cherokee laredo power lock problem 2wdGrand ZJ Grand Cherokee Forum 3 07-11-2007 09:16 PM
Rear Hatch Power Lock Problem????? skisprinkle686 ZJ Grand Cherokee Forum 6 05-07-2007 05:16 AM
Power Door Lock Buzz / Door Lock Duck Noise - Power Door Lock Actuator Solution Coppell-Jeep ZJ Grand Cherokee Forum 4 01-11-2006 10:25 PM
